Anyone know how to update nav firmware?
Old Oct 14, 2011 | 07:00 PM
  #76
beetle_orange's Avatar
yes you are out of luck. you can add bluetooth buying the extra hardware but not the fuse.
Old Oct 30, 2011 | 06:18 PM
  #77
msb175's Avatar
Originally Posted by Buru_EvoX
has anyone tried using the bluetooth with an apple device running iOS 5??
I just did this update and now it looks a like my 4s won't sync with the car anymore. They're not discovering each other.
It was working before...
Old Oct 31, 2011 | 10:19 AM
  #78
kedm's Avatar
It works fine with my iPhone 4 running iOS 5; I even get track titles over bluetooth now.
Maybe try re-pairing your device?
Old Oct 31, 2011 | 03:04 PM
  #79
msb175's Avatar
Yup. Tried repairing and now it's fine. All good. Takes a while to read the phone when I plug it in, but I guess that's expected.
Old Nov 2, 2011 | 07:17 PM
  #80
Buru_EvoX's Avatar
Yup, my Iphone 4S works perfectly fine over BT
Old Nov 22, 2011 | 04:00 PM
  #81
sppj's Avatar
after some tries, finally got a USB drive to start updating, but my update got stuck at 18% and then it shows update fail. I've tried to go back to redo but it keeps showing as update fail. Is dealership my only option now? thanks
Old Nov 22, 2011 | 07:55 PM
  #82
5p4rky's Avatar
I tried this fix as I have a 6th Gen iPod Nano that would work once and then require me to cycle three other devices before the iPod would work again. Otherwise it just got stuck at Load.
Every time I tried the update I got the "no file" error as well (from multiple USB devices). Not sure if anyone has found why this occurs yet?
I have confirmed I'm on the old software too.
What I found though is if I added a playlist to the device everything works perfectly. I don't need to use the playlist, I just have to have a playlist on the iPod. Hopefully this might help anyone else who is unable to/reluctant to run update.
Old Jan 23, 2012 | 04:04 PM
  #83
kahuna001's Avatar
2011 GSR. Updated the firmware. Works like a charm. Thank you all.
Old Jan 25, 2012 | 09:33 PM
  #84
Josephhdang's Avatar
does it matter what CDDB or/and MMCS version you got?
I have
CDDB: 2592-000
NR-261UM 1.09 61.01
So does anyone try to update it with similar versions at all?
Do you recommend a CDDB update?
Old Mar 29, 2012 | 11:22 PM
  #85
ProcessorHog's Avatar
Thank you so much OP for posting this. Worked great on my 2011 Outlander Sport. Took about 6 minutes.
Anyone with the non-navi system have track names working over bluetooth? And how can you go back to folder browsing once you play something based on a playlist/artist/album? I was hoping these would work after the update but no luck..
Old Apr 28, 2012 | 04:20 PM
  #86
Iainc216's Avatar
Thumbs up Worked great
Worked great on my 2011 GSR. Thanks for posting this update!
Old Oct 17, 2012 | 08:24 PM
  #87
jocson's Avatar
It sounds like this is the v9.0.0 update. Does anybody have the v11.0.0 update file?
Old Oct 20, 2012 | 11:51 AM
  #88
RawREvO's Avatar
I just did this and I lost the voice commands is that normal??
On a 2011 GSR EVO X
Old Oct 31, 2012 | 01:00 AM
  #89
WhiteTiger's Avatar
Does anybody know how to downgrade fuse software? I updated to 11.0 and now i got some metal echoes when speaking via handsfree.
Old Oct 31, 2012 | 03:50 AM
  #90
WhiteTiger's Avatar
Nvm, get 9.00 back.
