Depo oem style headlights
Old May 17, 2014 | 10:29 AM
  #316
Noize's Avatar
EvoM Administrator
Originally Posted by ayooo_itzme
Just to clarify .
I have a 2014 GSR BASE w/o SSS
The best option is to get
1. Depo Headlight
2. EvoX-R Projector
Anything else ? I'm new to evos so I would love the help to understand .
Do we have DRL? So do we need the JRox harness ?
No jrox harness req'd. You'll also need a. HID kit (ballasts and bulbs). Morimoto at the retrofit source is really nice.
Old May 17, 2014 | 07:54 PM
  #317
whatever210's Avatar
Wow these headlights look great. I wanted to do some hid but did not want to put them in the reflective housings. I would just put a thin layer sealant around the headlight to make sure it doesn't leak. With an HID kit these look great. Very impressed that I may order some of the future
Old Jun 12, 2014 | 10:52 PM
  #318
Noize's Avatar
EvoM Administrator
Anybody else have rotational adjustment problems with these. Mine are angled up quite a bit on the outside, and it doesn't seem correctable by the adjustment screws. Thanks.
Old Jun 13, 2014 | 01:39 PM
  #319
JP3NS's Avatar
Ya. The left and right adjustments are seated well however the up and down adjustment screw is seated in a soft plastic housing amd doesnt allow for much movement for some reason. This is the one flaw I noticed with these hls.
Old Jun 13, 2014 | 02:00 PM
  #320
momostallion's Avatar
the plastic nuts for the alignment screws are trash. we should have some billet replacements made.
Old Jul 4, 2014 | 02:47 PM
  #321
Armando0766's Avatar
Purchased a set from Amazon, installed Evox-r projectors, and Blacked out...... Best modd ever for base evos. Light cut off is on point.
Attached Thumbnails Depo oem style headlights-1979088_437915293010581_7910294248121489166_o.jpg   Depo oem style headlights-img_7347.jpg
Old Jul 5, 2014 | 12:29 PM
  #322
aceboogX's Avatar
Looks good been meaning to do this but every time im ready to order all this something breaks most recently the damn ayc/acd pump
Old Jul 24, 2014 | 07:06 AM
  #323
kanovic's Avatar
How much did it cost you for the headlights and projectors? And what hid kit did you get?
Old Aug 7, 2014 | 08:30 PM
  #324
evoXBora220's Avatar
has anyone found a great DIY retrofit for these?
Old Aug 8, 2014 | 07:18 AM
  #325
Veronica's Avatar
Huh? I thought it was required!
Unless you mean the kit comes with the relay/harness included...
Old Sep 7, 2014 | 07:50 PM
  #326
Magnus82's Avatar
So I recently did the HID retrofit on the Depo headlights and it turned out pretty well. Even though it was my first time working on headlights, I would give it a 4/10 for difficulty and it was pretty fun. Definitely things I could do better.
I'm not sure if this is fairly common, but the fitment was definitely about a 8/10. There is a noticeable gap on the lower edge under the projector and no amount of adjusting the bumper or headlight can get rid of.
Old Dec 15, 2014 | 07:42 AM
  #327
02modlanceroz's Avatar
Do the lancer gts depo headlights fit the Evo? In the descriptions I found it says it doesn't fit the Evo. I'm looking to get a set of depo projectors and do a retrofit swap to run HIDS. Just want to make sure they will bolt in before purchasing.
Old Dec 15, 2014 | 08:11 AM
  #328
sgtr275's Avatar
If it makes you feel better, my car is stock and has about 1/2" gap there on each side.
Old Dec 15, 2014 | 02:49 PM
  #329
dw0095's Avatar
The physical headlight housings are the same size and mounting locations. May be some different wiring harness with the SSS package drls
Old Dec 19, 2014 | 09:15 AM
  #330
ryanwheat's Avatar
i recently had these retrofitted and got 55w 6k hids. However, for some reason the parking lights/license plate lights & ccfl halos (wired to parking lights) dont work now. mine is a 2010 non sss so i need the jrox kit for the DRL flickering issue. I was wondering if that would remedy the parking light problem. I've checked all fuses and wiring seems to be fine. When i take the HIDs out and put the halogen back in everything works fine. I'm just hoping the Jrox kit would fix the issue.
