Depo oem style headlights
Old Mar 24, 2014 | 05:48 PM
  #286
dw0095's Avatar
The evox-r reflector housing is much larger than the depo. Can't really photograph the difference in lens but the evox-r appears to be thicker with great magnification. I can't believe a shop charged you more than the lights cost for installation and it's not to your liking. Did you try going back there?
Old Mar 24, 2014 | 06:02 PM
  #287
Noize's Avatar
EvoM Administrator
More adjustments.
The real reason you want to go the whole way and retrofit. Because bixenon brights.
Insane illumination.
Old Mar 24, 2014 | 06:13 PM
  #288
Noize's Avatar
EvoM Administrator
Originally Posted by Buguy
Will that be able to fix what's circled in red though with proper alignment and aiming?
It should get better. I almost think the HL is not seated completely straight in the projector housing. You'd need to pull that one to verify, or have really tiny hands. :/
Sorry.
Old Mar 24, 2014 | 07:16 PM
  #289
Buguy's Avatar
Well that isn't good
Old Apr 5, 2014 | 08:02 PM
  #290
elocinX671's Avatar
Anyone that is running these Depos with Evox-R and Morimoto d2s ballast, how did you fit the d2s plug into the headlight?
I drilled a hole at the bottom where the OEM ballast goes, but the headlight hardware and black plastic shroud is not allowing me to get the plug in.
I can get it in with the headlight completely disassembled. But that would be a PITA in the future if I ever needed to replace the ballast.
My last resort is to cut off the plug wiring and re-splice it together, but I would rather avoid that.
Old Apr 8, 2014 | 07:18 PM
  #291
evoXBora220's Avatar
Great job on the retro. was there a lot of trimming you had to do?
Originally Posted by Noize
More adjustments.
Old Apr 9, 2014 | 05:41 AM
  #292
dw0095's Avatar
Noize gave me a few pointers during the process and I can confirm that no trimming is necessary. Evox-r and depo projector are perfect swap. The only difference, other than bi xenon, is the depo has 4 screws holding the reflector housing to the lens piece and is held in to the headlight housing by 2 separate screws. The evox-r has 4 screws holding the projector assembly together but you have to use the two bottom screws to attach to headlight housing. Not sure if this changes the geometry or alignment at all but it seems to be okay. Here is my cutoff line using a very cheap 35w 9006 hid kit. Will be installing my morimoto stuff when I get the time.
Old Apr 9, 2014 | 08:11 PM
  #293
sweet thank you for the info. i currently have TL-zKwrz retro'd on my non SSS headlights done by a local cat. retro was fine but the finish and seal was Ok. im truly considering this retro.
Old Apr 9, 2014 | 08:42 PM
  #294
JP3NS's Avatar
Did one light today. Took me about 5hrs. It was my first time at something like this so I was carefull and the next one should take half the time. It came out great!
[IMG][/IMG]
[IMG][/IMG]
Old Apr 10, 2014 | 05:46 AM
  #295
kosteniuks17's Avatar
What kind of paint? Coats? Did you sand at all?
Old Apr 10, 2014 | 07:41 AM
  #296
dw0095's Avatar
Any high heat spray paint will work.
I used duplicolor primer and duplicolor engine enamel paint.
Hardest part of the project is making sure you sand/rough-up the chrome finishes off as much as possible using 600 grit paper. The better sanding you do, the better the finish.
2 or 3 coats of primer and 4 coats of paint. Very light coats for first just to get the primer and paint to stick and progressively heavier as you go. Make sure you don't wait longer than 30 minutes after last coat of primer to apply paint.
Old Apr 10, 2014 | 03:00 PM
  #297
JP3NS's Avatar
I used plasti dip. it should hold up well being that people put it on the wheels and it seems to hold up there. I guess time will tell.
Old Apr 11, 2014 | 09:54 AM
  #298
alsong2002's Avatar
does the adjusters work with evox-r retrofit?
Old Apr 11, 2014 | 10:45 AM
  #299
dw0095's Avatar
Not sure if you are talking about the 3 adjustment screws or the SSS package electric leveling system.
The retrofitted evox-r projectors are adjusted by the 3 screws on the housing.
Old Apr 11, 2014 | 11:39 AM
  #300
alsong2002's Avatar
i had a depo headlight retrofit with evoxr. what 3 screws that can adjust the light. which one is to adjust side by side or aiming. which one is up and down
