h.I.d light problems?
Old Jun 26, 2013 | 07:54 PM
PaulyX's Avatar
Talked to a mitsubishi rep and he said people try to put in h.I.ds in the car and it messes with something inside the electric wiring. Anybody get aftermarket h.I.ds in their X with no problems?
Old Jun 27, 2013 | 03:13 AM
way2low01's Avatar
Messes with the oem wiring circuit? Doubt it. It does however mess with every other drivers sight on the road. Do it right and install projector lenses.
Posted from Evolutionm.net App for Android
Old Jun 27, 2013 | 10:53 AM
Veronica's Avatar
You need a daytime running lights (DRL) defeat harness (J-rox).
Properly ground the ballast chassis. It really affected my radio reception when the lights were on.
My HID conversion does not have people flashing me and is aimed correctly. But, best is to have the proper housings.
Old Jun 27, 2013 | 08:40 PM
Hippie422's Avatar
He probably just meant if you just connect HID bulbs to the OEM sockets then that would cause problems.
Old Jul 16, 2013 | 12:45 PM
zebra4's Avatar
This, or you can make a DRL disable with only a few parts on your own. 5 pin relay, connectors, and wire. It took me about 15 minutes and cost $12 to do mine. If you don't disable the DRL, they HID's will flicker, or not turn on at all due to the low voltage for the DRL.
impact blue
Jun 25, 2011 12:38 PM
robyn402
Nov 28, 2010 03:43 AM
xXEVOloverXx
Mar 5, 2008 05:52 PM
crayonshinchan
Canadian Forum
12
Jan 22, 2008 05:30 AM
theo epstein
Jul 5, 2005 08:54 AM
