lancer evolution x illumination package
Old Jun 12, 2015 | 10:34 AM
  #46
confusingboat's Avatar
Originally Posted by MRevolutionX
Have any pics?
Also, any idea what the OEM footwell LED kit consists of? I would assume it should be mostly plug and play, meaning some sort of plug/connector that might save the hassle of all of this wire tracing and tapping/splicing. You might be able to buy it, plug it in, then splice whatever crazy LEDs you want into that harness.
...unless of course it doesn't come with a harness and instead gives you some T taps or something. Anyone have any experience with the OEM kit???
My '15 has the OEM kit. If memory serves me right, they're t-tapped. I'll try to get some pics once I get home. I remember looking inside the fusebox area during my dashcam install and thinking "really?" lol
Old Jun 15, 2015 | 01:30 PM
  #47
TxFAkuma's Avatar
Originally Posted by ixnine
I just finished mine, I had to use the gauges fuse, because optional stayed on without power.
^^^ (Original Poster) So, this is NOT what i was talking about but it looks good man. Good job on your install. When i bought my Evo X it came with the illumination package already and it was good enough for me. With what you did here in the picture above looks good but i would of used the dome light fuse instead powered with a on and off switch..
Anyway, Since my car came with the illumination package already i installed LED lights into my MAP lights and DOME lights and under my DOORS. That is what i was asking how to do in the beginning. I ended up wiring the LED's under the panels and used 20lbs double sides tape to make sure they stay there for a long time threw winter and summer.
Old Jun 15, 2015 | 01:37 PM
  #48
TxFAkuma's Avatar
Here is what i did. LED under the door panels. They shine VERY BRIGHT inside the interior while the doors are shut and it simply looks amazing on the ground. Did it on all the doors. When the car door opens it opens up to 120 LED's that shine the ground and gets so much attention it is sexy lol. Not to mention i put LEDs in all the map lights and dome lights. I wired these lights to a on and off switch i placed under my steering wheel.
Old Jun 17, 2015 | 06:06 PM
  #49
MRevolutionX's Avatar
I'm looking forward to checking it out!
So I just received my kit and thought I'd post an update. I didn't have time to snap any pics and upload them yet - I'll try to do that this weekend.
But basically, the kit has a passthrough wire with a male and female connector and the little wire section in between is essentially T-tapped. So, you unplug a connector from the fuse box, plug it in to the female end of this kit, then plug the male end of the kit into the fuse box. It's just like a T-tap but you're just clipping in plugs rather than cutting any wires (which makes me feel a lot better about the mod).
I will say though the instructions basically have you remove your entire dash (gauge cluster, head unit, glove box, trim strips, plastic panels by the doors, etc.). So, this might not be something for the faint of heart. I might try to do something different to avoid damaging my car. maybe just splice longer wires into this kit and run under the dash somehow... at least I'm not butchering up the OEM wiring this way either.
Like I said, I'll try to get pics of the kit and some of the instructions up soon.
Old Jul 9, 2015 | 12:17 PM
  #50
BlackHawk_Tsi's Avatar
just a thought to whomever reads this. the fuse could be before the relay therefore the fuse has constant power. Battery+> 10amp fuse> 12v relay> lamps/cigl ighter/cluster etc. wire diagram would tell what's true.
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
jzapatajr
17
Jun 2, 2020 06:44 PM
uneekvisions
14
Apr 8, 2018 08:57 PM
cerevo
12
Mar 14, 2017 06:58 PM
TxFAkuma
Jul 20, 2016 02:02 PM
