Bluetooth retrofit questions
I'm currently in the planning phase of adding bluetooth audio streaming to my car. A few questions regarding that:
All the threads on the matter say I need the N-04 8750A209 or N-05 8750A238 head unit for this. Unfortunately, I was born on the wrong side of the pond, so just to be sure I have to ask: are E-04 8750A210 and E-05 8750A239 effectively the same? The OEM numbers are off by one so I would assume that it's only some trivial modifications for the European users, but I'd like to be sure. What about E-06 8750A327? The bigger numbers ought to mean newer and better, I would assume, but there's no US equivalent and therefore no information.
Secondly, I'm starting with the basic CD reader head unit, which seems to complicate things. A lot of new parts seem to be needed, going by this thread: https://www.evolutionm.net/forums/la...s-upgrade.html
However, it would seem as though most of those parts are unnecessary if I don't care about GPS navigation. Am I correct in figuring that all I really need besides the head unit itself is 8750A225 Lancer CAN Interface Module, 8701A168 MMCS mounting bracket, and 8785A049 Bluetooth/Handsfree module?
Regarding the BT module, according to other threads what I need for FUSE is 8785A025. Are those two parts equivalent? And as I'm writing this, I also found out about 8785A026 and 8785A050 - another pair of off-by-one OEM numbers. Is that once again some EU-vs-NA parts thing? Doesn't seem to be, since I can actually find all four of these on used car parts websites here. Can I just pick whichever is cheapest?
I suspect the inevitable recommendation will be to get an aftermarket Android head unit for much less money and probably also less fuss, bother and itch. I'll pre-emptively reject this suggestion on the basis that I don't like huge touch screens, I think the MMCS looks much better, has actual buttons, and probably also doesn't sell my data or report to Beijing as much.
Third, if I'm putting a screen on my dash, might as well add a backup camera, too. Can't find much information about that, what's the best way of doing this?
Fourth, I'd like to retrofit the Rockford Fosgate audio. I know everyone says it's not very good and a custom system makes more sense, but in my particular case I have a base model Lancer waiting for the junkyard, which has the RF in it, and I see no reason to not take the free upgrade. How complicated would it be to make that swap?
I would see if there is an audio installaton site like Crutchfield they might have access to the information you need as well.
Except as far as I can tell, there is no reason for me to get the specific parts for my model year. Especially if I were to have a pre-2011 car, because some of the pre-2011 parts, particularly the head units themselves, weren't FUSE compatible anyway. If I wanted bluetooth on my 2008 Lancer, I absolutely should not get the 2008 parts regardless.
CT9A037
Evo X How Tos / Installations
55
May 18, 2026 01:00 PM
Harro
Nov 5, 2014 01:36 PM
Jackyll
Oct 24, 2008 07:16 PM
