ECUFlash 1.40 is out!!!
Old Nov 14, 2008 | 12:58 PM
  #256
Rguy's Avatar
Originally Posted by Rguy
So uhm....anyone have a cleaner XML i can have?
Beuller?
Old Nov 15, 2008 | 07:05 PM
  #257
gunzo's Avatar
Originally Posted by razorlab
Just like on the 8 and 9, yes, the WGDC goes above 100 in the table but it will not give you anymore boost. I've tried, trust me. You can put 127% in the WGDC table and not only will it not give you more boost, it will log only 100% as well. (on the 8/9 as we can't log WGDC on the 10 yet)
Do you guys with the JDM 10's have boost logs? I would be curious to see them plotted with WGDC.
Sorry .. not yet .. you'll be the 1st to see it though
There's taper .. but definitely not what you're posting .. maybe its conversion factor thats why we have this discussion ?? Consistent taper from 6500rpms @ 1.55bar to 1.35bar at 7000rpms .. It may be a flow limit, butEBC equipped cars doesn't have this taper .. maybe like what you mentioned .. could be a "leanspool" like function somewhere thats limiting this and fuel ..
I'm still testing it .. but I get higher load and boost above 100% ..
Rguy & Xbox4414 - There's no 'new' version but it depends on what you've got ..
Should be able to control idle very soon .. the subroutines are located .. its just a matter of labelling them correctly ..
"big brother" is watching ..
Old Nov 15, 2008 | 09:52 PM
  #258
RazorLab's Avatar
So you actually haven't logged your boost then? Just eyeballing it off a gauge? If you are using PCMscan, you can log absolute boost in kPa. It maxes at 255 kPa but you won't hold that up top anyway.
Did a TBE with HFC cat and open cone air filter Evo 10 today and with the stock boost system at 100% WGDC I got 17.5psi at 7,000 rpm, which is 1.2bar. Inputting anything over 100% WGDC did nothing more.
Old Nov 16, 2008 | 02:31 AM
  #259
gunzo's Avatar
I meant I haven't dynoed mine with a nice graph
My logger shows 1.35 bar at 7000rpms .. and that's stock exhaust and cat ..
Interesting .. at 127% I run 1.8bar peak and constant 1.7bar till 6500rpms ..
at 100% I run 1.6bar peak and 1.5bar till 6500rpms .. seems to be a magic number there
Found another boost vs temp map .. too many limiters on the stock ECU .. sigh ..
Old Nov 16, 2008 | 02:37 AM
  #260
RazorLab's Avatar
I'm beginning to think the JDM 10's have a different pill in the boost assembly then.
You seeing more boost with more than 100% wgdc I can't explain though. I've tried it on 6 USDM 10's so far and none of them increase boost after 100% wgdc.
Can you post up a screenshot of your logger?
Old Nov 16, 2008 | 03:18 PM
  #261
SiC's Avatar
SiC
Here's a short log of mine in 3rd gear (around the 20 second area). My boost spikes to 27psi and drops to around 22 psi by redline on my boost gauge. On PCMScan it shows 255 and drops to around 245 by redline. The boost is slightly higher in 4th gear but I really don't have an area that I can max out 4th gear safely for logging.
http://www014.upp.so-net.ne.jp/sic/log.zip
Old Nov 18, 2008 | 10:38 PM
  #262
onboost's Avatar
bump for eta. (beta testers)?
any new maps found?
what about that speed cut?
Old Nov 18, 2008 | 11:39 PM
  #263
SiC's Avatar
SiC
Originally Posted by onboost
any new maps found?
There are a few new maps and some maps have been renamed.
Speed cut was only for the JDM but that has been taken care of too.
Old Nov 19, 2008 | 01:34 AM
  #264
xbox4414's Avatar
Is there an XML for these "updates" so I can see what has changed in the definitions?
Old Nov 19, 2008 | 01:59 AM
  #265
gunzo's Avatar
2 screenshots of my logger
7000rpms 1.35 bar .. stock exhaust and cat
2nd 2500+rpms 1.5bar
Attached Thumbnails ECUFlash 1.40 is out!!!-image012.jpg   ECUFlash 1.40 is out!!!-image015.jpg
Old Nov 19, 2008 | 09:01 AM
  #266
drewgray's Avatar
Gunzo, you have the wastegate mod though, don't you?
at 7000, with the wastegate mod, and stock bcs I am hitting 18.5psi in 3rd gear.
Old Nov 19, 2008 | 10:17 AM
  #267
RazorLab's Avatar
Thanks for the log! Hopefully we can find that 100% WGDC cap on the USDM cars so they can boost more without upgrading pills.
Old Nov 19, 2008 | 06:35 PM
  #268
1BADEVO8's Avatar
Ok so I just downloaded the software and I'm goin to get my cable tommorow but how the hell do I use this stuff. Anyone in the NC area wanna meet up and give me a run down on this prog?
Thanks,
Jesse
Old Nov 19, 2008 | 07:09 PM
  #269
dollar99's Avatar
Thanks,
Jesse
I don't think the version you downloaded will work.
Old Nov 19, 2008 | 07:18 PM
  #270
1BADEVO8's Avatar
Ok. Is there a more current version available? Would I be able to use the 1.40 to aleast view how the program operates?
Thanks,
Jesse
