Purchasing a car with an Ecutek, want to reflash to stock
Old Dec 17, 2008 | 02:26 PM
Rguy's Avatar
Originally Posted by HB Speed
That is not always the case...
Ecutek is like anyone else $4-5K gets you software regardless of your "ability"
I have seen Dozens of Ecutek tuners that couldn't tune a damn guitar never mind a Car...... but thats just my opinion.
really? I inquired about getting the ECUTek software and was thrown a bunch of questions about what dyno i had, my experience, my business name and location, and more. totally turned me off.
Old Dec 17, 2008 | 02:56 PM
Q15H's Avatar
This is because the AP has the stock maps within it, you can install the AP and switch to the AP maps or the stock maps.
it includes a "stock-like" map - which is NOT the stock ECU image. From their website:
"Stock style map. Uses stock fuel, timing, and boost values for conditions when you need the vehicle's ECU to act like it is still stock. DOES NOT UNINSTALL AP FROM VEHICLE."
Perhaps it's close, but not same.
Old Dec 17, 2008 | 03:13 PM
HB Speed's Avatar
Well you kind of need to have a shop....
or at least a facility to tune at ....
Old Dec 17, 2008 | 04:10 PM
Rguy's Avatar
I wanted it to tune my own car at my local shop.
Old Dec 20, 2008 | 03:10 PM
STi2EvoX's Avatar
To the OP: AP can overwrite ecutek. I did this on my old sti no problem. As far as the stock map is concerned, on a stock ecu'd evo, if you "unmarry" the AP then it would revert back to the original image flashed to the ecu from the dealer. If you just loaded the "stock like map" that comes with the AP then the car would run the exact same as the stock tune, but you're right that it wouldn't be the exact image that came on your car. Since in your case, if you unmarried the AP, it would revert back to what the ecu image was prior to installation which in your case would be the ecutek tune, and that's your concern I assume? I'm guessing you're worried about your warranty if it were discovered that your ecu had been tinkered with, but dealers almost never check for a reflash because it is extremely difficult and if they don't suspect it's there, there is no reason for them to even bother. Plus, there has never been a report on EVOM about a warranty being voided from a reflash, most likely because no dealer has ever looked or been able to detect one, so I think you're making a big deal over nothing.
Old Dec 21, 2008 | 05:22 PM
HighWayDrifter's Avatar
i talked to cobb, they said it should work. if it doesnt i can send my ecu to them and they can hack at it.
DynoFlash
Evo X Dyno Results
Feb 28, 2010 10:47 PM
troe666
Nov 4, 2008 01:44 PM
Jooyoung99
May 14, 2008 04:55 PM
tsherriff
Jan 31, 2007 04:41 PM
AutoXer
May 26, 2006 03:36 PM
