TephraMODs for the X
What are the requirements for being a good input?
As in, would something like the fact that we don't have IC Spray work? I'd prefer to use an actual spare rather than the fuel pressure, but if it's hard to find...
I think IC button is hooked up to an IOPort input rather than an ADC.
But yeh that might be a better idea...
Let me take a look at the IC code to see what I can see... they might have changed to an ADC like CruiseControl...
yeah u need to insert a wire
thats what I have done for the fueltank pressure on mine, just rammed a wire into the wiring harness...
i tried using evo ix pins, but they are too big...
well there will be two (maybe 3) activation methods for map switching
1) cruise control holding down to switch maps - good for E85, or different fuels
2) voltage input into ECU - good for meth failsafe switching
3) might use TPS as well - depending on whether people want it (not really needed since CC will do the job)
so with #2, its working now with the fuel tank pressure input... BUT this isn't very easy on USDM.
So on USDM I might use the IC setup - which means you will need a 5v relay to switch +12v to the IC input...
most meth failsafes are +5v, the IC will expect +12v...
wont be too complicated
Keith
