correct stat rev limit ECUFlash definitions for USDM Evo 10 GSR
Old May 18, 2009 | 05:58 PM
mrfred's Avatar
A few people have mentioned that the stationary rev limit is not working for their USDM Evo 10 GSRs, e.g.:
https://www.evolutionm.net/forums/ev...v-limiter.html
Turns out that the stat rev limit definitions in ECUFlash 1.41 are incorrect, at least for USDM Evo 10 GSRs. The correct definitions for the USDM Evo 10 GSR are below. If you follow the instructions here, it will work for any USDM Evo 10 GSR (52680015 to 52680020. Paste everything between the "----" into the "52680015.xml" file and ignore the old stat rev limit definitions. I don't have time to find the correct stationary rev limit definitions for the other ROMs. Hopefully, other people can figure it out by looking at offsets between addresses of known items.
<scaling name="VehicleSpeedFreq" units="km/h" toexpr="x*0.25" frexpr="x/0.25" format="%.1f" min="0" max="64" inc="0.2" storagetype="uint16" endian="big"/>
<table name="Stationary Rev Limit" category="Limits" address="54670" type="1D" scaling="RPMStatLimit"/>
<table name="Max Speed for Stationary Rev Limit" category="Limits" address="5466e" type="1D" scaling="VehicleSpeedFreq"/>
<table name="Stationary Rev Limit Cross Under Max Speed Enable Delay" category="Limits" address="54672" type="1D" scaling="Time"/>
EDIT: Changed "Misc Limits" to "Limits" so that the definitions show up in the correct place in ECUFlash.
EDIT: Changed the destination for the definitions from "52680015_mods.xml" to "52680015.xml".
Old May 18, 2009 | 06:16 PM
LaXGSR's Avatar
Thanks mrfred! Anyone want to figure it out for 52680018? Or could someone post a 52680015 ROM so I could take a look at the offsets in there relative to 0018?
Old May 18, 2009 | 07:41 PM
mrfred's Avatar
It works for all the USDM Evo 10 GSR ROMs if you paste it into the file I mentioned.
Old May 18, 2009 | 08:15 PM
droppinbottom's Avatar
I've been wondering what you have been up to. Got any plans for this weekend?
Old May 18, 2009 | 08:51 PM
mrfred's Avatar
Originally Posted by droppinbottom
I've been wondering what you have been up to. I got my boost pill in the mail today from GST. Got any plans for this weekend?
I've probably gotta finish rebuilding my deck this coming weekend. Fun stuff. :-( If you're willing to help, I could make time to help with your Evo if you want. :-) And I could show you my ethanol sensor and gauge install. I did such a good job, I feel like I have to show someone. :-)
Old May 18, 2009 | 11:13 PM
Hiboost's Avatar
Hmm, maybe I'm stupid but I pasted this into that 52680015_mods.xml file under the "Limits" section and things look the same as before. When access my rom in EcuFlash it shows the ~5500 limit but I know it was set to 6k by EcuTek. It still may work but I guess I was expecting it to have the 6000 rpm limit in the field. Maybe there is another spot as well?
Turns out that the stat rev limit definitions in ECUFlash 1.41 are incorrect, at least for USDM Evo 10 GSRs. The correct definitions for the USDM Evo 10 GSR are below. Paste everything between the "----" into the "52680015_mods.xml" file, and ignore the old stat rev limit definitions. I don't have time to find it for the other ROMs. Hopefully, other people can figure it out by looking at offsets between addresses of known items.
<table name="Stationary Rev Limit" category="Misc Limits" address="54670" type="1D" scaling="RPMStatLimit"/>
<table name="Max Speed for Stationary Rev Limit" category="Misc Limits" address="5466e" type="1D" scaling="VehicleSpeedFreq"/>
<table name="Stationary Rev Limit Cross Under Max Speed Enable Delay" category="Misc Limits" address="54672" type="1D" scaling="Time"/>
Old May 18, 2009 | 11:38 PM
mrfred's Avatar
I used "Misc Limits" instead of "Limits". I'll fix the defs in the first post so that they show up under "Limits". Remember to ignore the old table.
Old May 19, 2009 | 03:58 AM
hawaiian_evo's Avatar
same issue here???
Old May 19, 2009 | 05:06 AM
I've probably gotta finish rebuilding my deck this coming weekend. A. :-( If you're willing to help, I could make time to help with your A if you want. :-) And I could show you my ethanol sensor and gauge install. I did such a good job, I feel like I have to show someone. :-)
Just give me a call when you are working on your deck. I should have some free time this weekend. I don't plan on installing the pill untill I can log boost.
Old May 19, 2009 | 08:00 AM
mrfred's Avatar
Originally Posted by hawaiian_evo
same issue here???
I made a slight change to the definitions so that they show up in the expected location. Paste the current defs in post #1 over the ones you originally added.
Old May 19, 2009 | 08:26 AM
Hiboost's Avatar
Wierd, I'm still not seeing it pick up the higher rev limit that I know EcuTek tune has set.
Old May 19, 2009 | 09:01 AM
mrfred's Avatar
The tables that I posted are definitely correct. Are you seeing them now?
Old May 19, 2009 | 10:12 AM
mrfred's Avatar
I just remembered that the as-installed version of ECUFlash does not automatically parse the "52680015_mods.xml" file, so that's why no one is seeing the new definitions. Move the definitions over to the "52680015.xml" file, and then they will definitely be visible (for USDM Evo 10 GSRs). I have updated the first post accordingly.
Old May 19, 2009 | 11:12 AM
Hiboost's Avatar
Ah good catch, I'm definitely new on the scene to EcuFlash but getting more familiar day by day. I'll test out the changes and see if it shows the higher rev limit after work.
Old May 19, 2009 | 06:23 PM
did anyone get this working?
