Quick AP question...
Old Nov 14, 2009 | 09:55 AM
Methodical4u's Avatar
i'm trying to remember how to get a map that I made through Access tuner race to the AP... it shows up when I put it on the AP manager, but not on the AP when I go to flash it.
Old Nov 14, 2009 | 02:23 PM
ScottSpeed21's Avatar
While you're in AP Manager and with the AP plugged into the computer, right click on the map and select "Upload to AccessPORT".
Old Nov 14, 2009 | 10:07 PM
when I right click all I get is...
Open containing folder
display
delete
edit
Old Nov 14, 2009 | 11:09 PM
something is not right here... i'm still trying to get this map on here and it's not even showing my basic installed maps in the AP manager, I have updated everything and still nothing... it's responding and updating the AP, but it won't let me add the maps... what is going on here?
Old Nov 14, 2009 | 11:18 PM
Just to confirm, you do have the AP USB plug connected to the computer and in the "Sources" column on the left side of AP manager it shows "AP Manager Library" and the connected AP correct?
Old Nov 14, 2009 | 11:36 PM
yeah it has all that... the connected AP part i'm not sure what you mean there though.
Old Nov 14, 2009 | 11:46 PM
I think I figured it out... I had to update the manager... which I thought I had done...
Old Nov 15, 2009 | 05:28 AM
You have to plug the AP USB cable into the computer, but the AP Manager also has to recognize that the AP is connected. In AP Manager, there's 5 buttons at the top left corner, under File, View, and Help. The button all the way to the right shows a small rectangle with a green arrow curving up, and if you hold the cursor over it, it says "Connect AP". With the USB cable plugged into the computer, push that button and it will connect the AP to AP Manager and it will pop up in the Sources column. Then just right click and upload the maps to the AP. Then before you unplug the USB cable, hit the same button which will disconnect the AP.
t3am 83rd
Cobb AccessPORT
Apr 28, 2016 08:16 AM
boyvang
Jul 16, 2015 07:17 AM
nothere
Apr 13, 2006 03:01 PM
Soon 2 B EVIL
Mar 5, 2006 08:08 PM
domestickilla
Jun 7, 2005 07:50 PM
