Evo X evoscan amptracer
Old Dec 27, 2009 | 11:28 AM
vboy425's Avatar
does anyone have any luck with Evoscan and got maptracer to work ? I can log in mod 23 just fine and open up the log using excel. But i wanted to use evoscan maptracer. The problem is that when i open my log using maptracer, it doesn't anything.
Old Dec 27, 2009 | 11:37 AM
criptballer's Avatar
you need the evoscan 2.7 beta 5. otherwise it won't work. do a little research someone posted a link to download it but i can't remember where.
ps. maptracer is *******!
Old Dec 27, 2009 | 12:37 PM
boostin20's Avatar
Heres a screen shot of it for the OP. For everyone else, what does the chart below mean? I don't understand the values in the cells.
Old Dec 27, 2009 | 07:48 PM
vboy425's Avatar
i do have 2.7 beta 5
it load my log just fine, but when i load my rom i get weird pop up. Also if you look at the load. it doesn't read right.
Old Dec 28, 2009 | 11:36 AM
vboy425's Avatar
bump for help
Old Dec 28, 2009 | 12:49 PM
E6-X's Avatar
try reinstalling. then right click to load your hex file. i reinstalled 2.6 then upgraded to 2.7 beta 5 and it works but a pop up saying " Couldn't find recognizable digits " but i just hit ok and it works my guess is that the rpm's dont match with the hex file & maptracer but it works though.
Old Dec 28, 2009 | 10:58 PM
^ yeah the same thing happens to me when I load maptracer but it works perfectly. Did you have 2.6 and then upgraded to 2.7 beta 5? Are your XML defenition in the right place inside your evoscan folder in you program files? I'll show you a print screen of what mine looks like and Ill answer any question Boostin20 might have too. I'm doing this on my iPhone since my Internet won't work till tomorrow, sorry
Old Dec 29, 2009 | 01:15 PM
vboy425's Avatar
the difinition form the ecuflash is in the evoscan rom folder now. still load cell are weird looking like in the pix. also i don't see anything when i lick on knock etc etc.
Old Dec 29, 2009 | 07:30 PM
ok sorry guys. this is what map tracer looks like when its working properly. i clicked on my external AFR's so you guys can see what it looks like. as you can see at WOT i'm hitting the 260 loads and barely going into the 280's. maptracer will only let you click on one item at a time but it's **** cuz it shows you exactly what you're hitting and when you're hitting it. Let me know if you guys have any questions.
Old Dec 30, 2009 | 12:43 AM
E6-X's Avatar
cripballer,
how do ou change the rpm values on maptracer ? mine has 2750, 3250 and 4250 rpm range, wanna get it changed same as in ecuflash. maybe i have to paste my latest xml into evoscan data folder ?
Old Dec 30, 2009 | 05:44 PM
Originally Posted by E6-X
cripballer,
your right click on the gray shaded area on the bottom and then you load your hex with the map that you ran your car with. mine did it automatically. let me know if that helped.
Old Jan 4, 2010 | 11:35 PM
E6-X's Avatar
yeah i right clicked to load the hex file but same result although it displays it but it says "Could not find any recognizable digits"
i'll go and do a few runs and test it out again ... thx for your help
Old Jan 5, 2010 | 11:15 AM
Let me know if anyone needs more help
EvilEvolution8
Dec 22, 2015 05:26 AM
drifterific
Sep 1, 2010 06:05 PM
lapulapu
Sep 21, 2008 04:20 PM
alicea8541
Feb 28, 2008 12:10 PM
lapulapu
Jan 27, 2008 08:51 PM
