Quick noobie question...
Old Jan 9, 2010 | 10:05 PM
SpeedI2acerX's Avatar
So I bought a code reader becuase I've been getting a ses light. I'm thinking it's my test pipe but don't want to take any chances. My question is if I plug and run the unit will it brick or mess up my ecu? Will I lose my tune?
Old Jan 9, 2010 | 10:13 PM
itoen's Avatar
I don't think you will lose your tune, it should just read the code but I'm not 100% sure, I have a test pipe too along with a down pipe and I added a cel fix to sensor 2 and it doesn't throw a code. Do not run a cel fix on the first sensor cause it will throw a slow to read code. I got my cel fix from gruppe-s but they sell them at alot of sites like AMS, Touge Factory, and e-bay. Good luck with that.
Old Jan 9, 2010 | 10:21 PM
I have an angle fouler for my test pipe. It's been fine for about 4-5 months until I got on pretty hard (WoT) then it came on. Reset it and was fine or another week then it came back.
Old Jan 10, 2010 | 10:34 AM
Bump! can anyone confirm that reading a code won't harm my ecu?
Old Jan 10, 2010 | 10:45 AM
ak47po's Avatar
It will not hurt anything,all it does is read the codes and won't delete the codes unless you opt to do so.
Old Jan 10, 2010 | 11:17 AM
javicracer's Avatar
u wont hurt anything and even if u erase the cods u wont hurt anything.
Old Jan 10, 2010 | 01:28 PM
awsome thanks guys. i did pull the code and its my test pipe (P0137) and it was able to erase it. i use the Autel Maxiscan ms300 if anyone is interested. for $30 cant beat it. now i just have to find or replace my fouler. im pretty sure it went bad or needs a little cleaning. i have the ichiba tp and an angle fouler. like i said its been fine for 4-5months, dont understand why it would just kick on again.
Old Jan 10, 2010 | 05:59 PM
kozmic27's Avatar
Or get a tune and disable that code.....
Fawkz
Aug 25, 2015 01:44 PM
oscarquinones
Aug 5, 2013 02:58 PM
22raptor
23
Sep 13, 2011 11:18 AM
deylag
10
Sep 4, 2011 12:27 AM
08bluegts1
Lancer Engine Tech
Apr 27, 2011 04:34 PM
