ASC Service Required c121c c1290
Old Feb 20, 2010 | 11:53 PM
turbolag4500's Avatar
Originally Posted by lespotts
Has anybody else experianced this fault????
i have in my x mr. when downshifting then flooring it, it will pop up the asc and service light almost like it went to limp mode for a split second. no cel's though. really weird.
Old Feb 21, 2010 | 01:49 AM
murlo26's Avatar
I have the same thing, I think it's the ASC looking at the airflow/torque limit tables. I am using the DTC disable (are you?) and I think my tables aren't fully dialed in since my tuner didn't think they needed to be with the disable.
Here is what Mitsubishi pulled for me for codes:
I have both the codes you are talking about as well.
Same scenario as you...I floor it, usually the higher gears for me, 4/5th and rarely 3rd. And usually when doing at a low RPM. The ASC light comes on and the dash looks like this.
Minus the seatbelt/brake lights, I was stopped when I took the pic
Old Jun 29, 2010 | 02:05 PM
Meth Addict's Avatar
any word on this? I'm having the same problem
Old Jul 3, 2010 | 02:42 PM
Red EVOX's Avatar
Yep my modded GSR does it but only when it boost spikes over 30psi.
Old Jul 5, 2010 | 07:32 PM
turbo26tsi's Avatar
Veteran: Air Force
mine did this before the tune briefly in low gears when boost spiking to 28psi, does it after the tune, not sure why since it was disabled during the tune.
Old Aug 24, 2010 | 06:16 PM
EvoXHoosier's Avatar
same problem!!!
Any resolutions to this issue? I am having the same asc and service required lights coming on. Just started a couple of days ago. I'm in the process of tuning the car right now with an email tuner. I thought it could just be data issues because of logging and all of that, but it happens when everything is disconnected also.
I'm running around 30-30.5 psi, and it happens right when I get into peak boost (I think in every gear, but haven't confirmed 1st gear yet).
Any comments would be great. Thanks
Old Aug 24, 2010 | 06:29 PM
Golden's Avatar
Yes it's been fixed.
https://www.evolutionm.net/forums/ev...off-fixed.html
Old Aug 25, 2010 | 02:00 AM
E6-X's Avatar
overboost 29.xx psi n above it pops out and like golden said it's been a fix. i suspect the tq/airflow tables has something to do with this ad probably throttle maps too
Old Aug 25, 2010 | 09:53 AM
GST Motorsports's Avatar
I found an interesting thing about this on my RA when I swapped to the BBX lite
The RA has different values in the 3D MAP tables. I didn't move the Evo values over to the RA tables and every time I went WOT, even at 23psi, it would trip the ASC service light. Also the load would get all richter scale looking and the car would generally be pissed off.
I moved over the Evo MAP values to my RA rom and everything went back to normal, no ASC service light and the car was much happier at WOT.
- Bryan
Old Jan 14, 2012 | 07:16 PM
faruk's Avatar
Hi
I have a UK Evo X Fq360 which under hard acceleration logs fault codes C121C Torque request signal rejection C1290 CAN time-out error. The amber ASC Service Required message is also displayed on the dash, but it is cleared every ignition cycle.
My engine spec is
Ultimate Racing o2 housing
Ultimate Racing decat & 3inch system
Ultimate Racing intercooler
AMS cold air intake
HKS intercooler pipes
AFI tubular manifold
HKS fuel pressure reg
Walbro 255 pump & remote filter
Deatschwerks 1000cc Fuel Injectors
FP red turbo
Peak boost 30PSI
Ecutek remap
520bhp/460lbft
The car will log this fault in every gear apart from 1st, but does not log when on rolling road. I suspect therefore that it is the G sensor logging to much acceleration on the road. Does anybody know what is needed to remove this fault code??
Cheers Les
i have similar issue as less, got a uk fq300 with intake, exhaust intercooler upgrade with a 400/400 ecutek tune on 98ron...punch my car at loww rpm in fifth gear and the asc, service message pops up,...
how is/was this resolved? please revert soonest, help. tnx!
Old Jul 31, 2020 | 01:08 PM
Matthew Blunk's Avatar
Hey super old thread, but I'm having this exact problem...and my car is being e tuned right now.
Is there any fix for this beyond evoscan and tephra? It looks like it's a map sensor problem, so can I just get a 4 bar sensor and throw it in?
I'm tuning with the accessport and almost done with my E85 tune, and this happens. So needless to say, switching to a completely different tuning platform set really an option at this point
drew08
31
Sep 2, 2021 03:59 AM
hiboost03
Mar 20, 2014 04:29 PM
Nega
Jul 25, 2013 12:44 PM
Indianbrandon
Dec 28, 2012 01:20 AM
martymil
Apr 15, 2011 05:56 PM
