EvoScan questions
Old Feb 24, 2010 | 04:53 PM
H Jensen's Avatar
Question EvoScan questions
Hey all, So i finnaly get evoscan and hook it up to the car, after some dumb luck i figure out that i needed to select openport 2.0 ect ect. Now when i did a log at idle between selecting Evo X and mode23 USDM Evo X i get diffrent results, one will show knock at idel and the other doesnt. Which one should i be using?
Also I wish this would read DTC's already!!!!
Old Feb 24, 2010 | 06:54 PM
newcomer81's Avatar
did you enable mode 23? if not look at the stickies in the top.
Old Feb 24, 2010 | 07:26 PM
SiC's Avatar
SiC
The newest beta version sent out to testers can already read/clear DTCs.
Old Feb 24, 2010 | 07:29 PM
Q15H's Avatar
If Mode 23 is NOT enabled in the ROM image in the car, then you cannot use Mode 23 logging.
If you have Mode 23 logging set in Evoscan with a non-Mode 23 ROM, you'll get only garbage in the logs.
Old Feb 24, 2010 | 08:27 PM
H Jensen's Avatar
So Mode 23 is better for logging correct? More accurate? If that's the case then I'll try tomorrow, and that's good news that the beta has DTC reading and clearing.
Old Feb 24, 2010 | 11:59 PM
E6-X's Avatar
I think it's the final release version which is V2.7 and i'm already using/testing it but i do stand to be corrected.
Haven't tried read/clearing any DTC's.
Yep, there's a big how-to on enabling mode23. Enable it then go out to do some DL using mode23.
Old Feb 25, 2010 | 12:15 AM
SiC's Avatar
SiC
Nah, there were more bugs so it isn't final yet. Also if you noticed the installer screen it said 2.8 and it tries to install into a directory called Evoscan 2.8
Old Feb 25, 2010 | 12:26 AM
E6-X's Avatar
mine was V2.7 didn't see any V2.8 . . . hmmmmmmm yeah i think there could be few bugs on it but it's working fine for me as of now.
Old Feb 25, 2010 | 02:54 AM
_Speedy_'s Avatar
Yeah, he said all EvoScan v2.7 FINAL Beta bugs are now fixed. just waiting for us beta testers to give him feedback. It includes EvoX Read and Clear DTC, and also a beta ECU RESET Learned Values feature, but this is still in progress.
darkmitsu
Lancer Engine Management / Tuning Forums
141
Dec 31, 2022 05:41 AM
twisty
Jul 15, 2016 11:01 AM
babaz7
Mar 10, 2016 07:17 PM
jrsimon27
Jun 4, 2009 09:13 PM
evo7girl
May 30, 2009 07:26 AM
