E85 Question
Old Apr 1, 2010 | 07:32 AM
EVOOOOO's Avatar
E85 Question
Sup Fellas,
I just recently found out there is an E85 station up the road from my house & im switchin over for sure. I have stock turbo but plan to upgrade to an FP Red eventually maybe bigger. What size injectors would i need? Also what other mods do i need to do. I kno there is a plastic piece in the fuel pump that needs 2 be replace & the fuel rail needs 2 be changed as well....What else needs 2 be done to run this safe?
Old Apr 1, 2010 | 07:52 AM
goofygrin's Avatar
There's this long thread with a really informative post about it in the hardware (not tuning) side about this forum... It might answer some of your questions...
Old Apr 1, 2010 | 08:09 AM
fostytou's Avatar
EvoM Community Team
I don't have a ton of experience on the X yet, but for a similar setup on the IX ~1100-1200cc injectors and a double pumper would be ideal for your future goals.
As far as mods required for running the E85 (if it hasn't been beaten to death and back): bigger injectors, replace the sock in the pump and/or replace the pump itself with a blaqops / buschur / etc kit, and most importantly tune.
Obviously all other supporting mods would be ideal to allow that setup to see its full potential.
Old Apr 1, 2010 | 09:29 AM
kmart888's Avatar
I am running DP 1000cc injectors and the Blaqops single 255 pump with 94% duty cycle at WOT. I really like the theory behind the progressive double pumper kit but so far have not seen a need for any more than a single 255 pump
Old Apr 1, 2010 | 09:53 AM
GST Motorsports's Avatar
Then you aren't making enough power yet.
The 10's will need the double pumper with a larger then stock turbo on E85.
I've maxed out the single pump at a little over 400whp on our dyno on the 10's.
- Bryan
Old Apr 1, 2010 | 02:26 PM
kmart888's Avatar
Originally Posted by GST Motorsports
Then you aren't making enough power yet. .....
You are right about that!
Old Apr 2, 2010 | 07:39 AM
EVOOOOO's Avatar
awesome guys i know this topic has been beaten to death & i honestly didnt have much time to run through the forums, I really appreciate your input & soon enough there will be numbers up with en E85 tune . Thanks again!
Old Apr 2, 2010 | 08:57 AM
mlomker's Avatar
If you were installing a new system today then I'd go with a BlaqOPs double-pump kit and the FIJ1100 injectors. I found the stock rail a pita to deal with. If you want to add some bling then the Boomba rail works perfectly with the BlaqOPs quick disconnects.
eliruiz
Lancer Engine Management / Tuning Forums
Jun 11, 2017 07:10 AM
99gpgtx
20
Mar 23, 2017 06:07 PM
LANEVOLIU
E85 / Ethanol
May 27, 2013 11:39 AM
YuLost2x
E85 / Ethanol
Sep 13, 2012 12:25 PM
Richard Sierra
AEM EMS
30
Mar 27, 2007 08:45 PM
