High idling RPM problem
Old Apr 24, 2010 | 07:46 PM
  #31
Optiblue's Avatar
Originally Posted by jackfrog
thats exactly what happened to my car, i got the 1.07 from cobb, and same result like you stated. i really want to know the difference between 1.04 and 1.07, i feel 1.04 is smoother...i dont know how to log lol. btw what mods you have? do you have wb and see how the car runs? i dont have one so i wanna know if everything is fine...>_<
I agree, with 1.07 I feel the shifts even in normal mode! I have a k&n dropin filter, t1r catback, and the t1r testpipe! No wideband, just using the ap to monitor knocks and all. For the most part the ots maps are safe. Some people run stage 2 without any exhaust mods and are ok. I'm running without a down pipe and so far so good. Logging is easy! Just go to logging on the ap and press log data. When you connect your ap to the comp, go into ap manager, and then press options at the top and select advanced. A window should pop up to dl all the log files, opens in excel and you're done!
Old Apr 25, 2010 | 07:17 AM
  #32
jackfrog's Avatar
i would try to log files. but how do i know everything is normal? i dont really know what those numbers mean.
Old Apr 26, 2010 | 08:13 AM
  #33
jackfrog's Avatar
im still using the 1.04 map, it is way better ride than 1.07 !!
just wanna know if anyone can send me the 1.04 map for USDM EVO MR, HSKPF, 93 OCT STAGE 2. thanks thanks
Old Apr 27, 2010 | 08:53 AM
  #34
5ynth3t1c's Avatar
If you look at the map notes for 1.06 cobb says they added ecu changes from the 2010 to the 2008 ecu maps. The v1.07 map is about the same as v.1.04 to me.
Old Apr 28, 2010 | 04:43 AM
  #35
jackfrog's Avatar
added ECU changes from the 2010 to the 2008 ECU maps?? confused.
after i installed 1.07, when the car downshift from 4-3, or 3-2 by self (sometimes there are couple seconds delay), i can hear the clutch sound and the car knocks a little bit.
Old May 18, 2015 | 10:00 AM
  #36
johnjodoinevox's Avatar
i have a similar problem but mine is bone stock....
Old May 22, 2015 | 11:01 AM
  #37
Rado_93's Avatar
I uninstalled the AP and am going Open Source on my SE. The AP just doesn't mesh well work our SST's. I had high idle issues and crazy problems with my trans. Shifts were clunky as all get out and I'd randomly get the "Service Transmission" warning. I even lost all the odd gears. Uninstalled the AP and the car runs great on the stock map!
Installed the AP on my friend's GSR and his car runs perfectly so I'm convinced that it's an MR/SE thing.
Old May 22, 2015 | 11:43 AM
  #38
I have a GSR! you think the AP will work fine?
Old May 24, 2015 | 05:15 PM
  #39
wilkes.1768's Avatar
Very helpful to know
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
khaled_hourani
15
Apr 24, 2017 04:10 AM
supwiddiss
Cobb AccessPORT
Jun 24, 2016 01:21 PM
hotredevo
Jul 29, 2010 06:54 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
