dtc codes p0098 & p0365
Old Nov 27, 2010 | 05:50 PM
dadsgts's Avatar
Hello wondering if anybody can help disable these codes p0098 and p0365. im using a 52680015 rom for the evo x gsr. any help would be great and i would be willing to pay for the help.
Old Nov 27, 2010 | 08:33 PM
evo 1768's Avatar
These is as complete a list as I know of and have codes for the EVO8, 9 and X.
DTC P0011: Intake variable valve timing system target error
DTC P0012: Camshaft position-timing over-retarded
DTC P0014: Exhaust variable valve timing system target error
DTC P0016: Crankshaft/camshaft (intake) positiion sensor phase problem
DTC P0017: '' '' (exhaust)
DTC P0031: Heated 02 (front) heater circuit low
DTC P0032: Heated 02 (front) heater circuit high
DTC P0037: Heated 02 (rear) heater circuit low
DTC P0038: Heated 02 (rear) heater circuit high
DTC P0069: Abnormal correlation between manifold absolute pressure sensor and barometric pressure sensor
DTC P0090: Fuel Pressure Solenoid Circuit
DTC P0096: Intake air temperature circuit range/performance problem (sensor 2)
DTC P0097: Intake air temperature circuit low input (sensor 2)
DTC P0098: Intake air temperature circuit high input (sensor 2)
DTC P0101: Volume Airflow Circuit Range
DTC P0102: Volume Airflow Circuit Low Input
DTC P0103: Mass airflow circuit high input
DTC P0106: Barometric Pressure Circuit Range
DTC P0107: Barometric Pressure Circuit Low Input
DTC P0108: Barometric Pressure Circuit High Input
DTC P0111: Intake Air Temperature Circuit Range
DTC P0112: Intake Air Temperature Circuit Low Input
DTC P0113: Intake Air Temperature Circuit High Input
DTC P0116: Engine Coolant Temperature Circuit Range
DTC P0117: Engine Coolant Temperature Circuit Low Input
DTC P0118: Engine Coolant Temperature Circuit High Input
DTC P0121: Throttle Position Circuit Range
DTC P0122: Throttle Position Circuit Low Input
DTC P0123: Throttle Position Circuit High Input
DTC P0125: Insufficient Coolant Temperature for Closed Loop
DTC P0128: Coolant Thermostat
DTC P0130: Heated Oxygen Sensor Circuit
DTC P0131: Heated Oxygen Sensor Circuit Low Voltage
DTC P0132: Heated Oxygen Sensor Circuit High Voltage
DTC P0133: Heated Oxygen Sensor Circuit Slow Response
DTC P0134: Heated Oxygen Sensor No Activity Detected
DTC P0135: Heated Oxygen Sensor Heater Circuit
DTC P0136: Heated Oxygen Sensor Circuit
DTC P0137: Heated Oxygen Sensor Circuit Low Voltage
DTC P0138: Heated Oxygen Sensor Circuit High Voltage
DTC P0139: Heated Oxygen Sensor Circuit Slow Response
DTC P0140: Heated Oxygen Sensor (rear) circuit no activity detected
DTC P0141: Heated Oxygen Sensor Heater Circuit
DTC P0171: System too Lean
DTC P0172: System too Rich
DTC P0181: Fuel Tank Temperature Sensor
DTC P0182: Fuel Tank Temperature Sensor Circuit Low Input
DTC P0183: Fuel Tank Temperature Sensor Circuit High Input
DTC P0201: Injector circuit-cylinder 1
DTC P0202: Injector 2
DTC P0203: Injector 3
DTC P0204: Injector 4
DTC P0222: Throttle position sensor (sub) circuit low input
DTC P0223: Throttle position sensor (sbu) circuit high input
DTC P0234: Turbocharger Wastegate System Malfunction
DTC P0243: Turbocharger Wastegate Solenoid 1 Circuit
DTC P0247: Turbo charger wastegate solenoid 2 Circuit
DTC P0300: Random/Multiple Cylinder Misfire Detected
DTC P0301: Cylinder 1 Misfire Detected
DTC P0302: Cylinder 2 Misfire Detected
DTC P0303: Cylinder 3 Misfire Detected
DTC P0304: Cylinder 4 Misfire Detected
DTC P0325: Knock Sensor Circuit
DTC P0327: Knock sensor circuit low
DTC P0328 Knock sensor circuit high
DTC P0335: Crankshaft Position Sensor Circuit
DTC P0340: Exhaust camshaft Position Sensor Circuit
DTC P0365: Intake camshaft position sensor circuit
DTC P0401: EGR Flow Insufficient Detected
DTC P0403: EGR Control Circuit
DTC P0420: Catalyst Efficiency Below Threshold
DTC P0441: Evaporative Emission Control System
DTC P0442: Evaporative Emission System Leak Detected (Small)
DTC P0443: Evaporative Emission Control System Purge Control
DTC P0446: Evaporative Emission Control System Vent Control
DTC P0450: Fuel tank differential pressure sensor malfunction
DTC P0451: Evaporative Emission System Pressure Sensor Range
DTC P0452: Evaporative Emission System Pressure Sensor Low
DTC P0453: Evaporative Emission System Pressure Sensor High
DTC P0455: Evaporative Emission System Leak Detected (Gross)
DTC P0456: Evaporative Emission System Leak Detected (Very Small)
DTC P0461: Fuel Level Sensor Circuit Range/Performance
DTC P0462: Fuel level sensor circuit low input
DTC P0463: Fuel level sensorcircuit high input
DTC P0500: Vehicle Speed Sensor Malfunction
DTC P0506: Idle Control System RPM Lower Than Expected
DTC P0507: Idle Control System RPM Higher Than Expected
DTC P0513: Immobilizer Malfunction
DTC P0551: Power Steering Pressure Switch Circuit Range
DTC P0554: Power Steering Pressure Switch Circuit Intermittent
DTC P0603: EEPROM malfunction
DTC P0606: Engine control module main processor malfunction
DTC P0622: Generator FR terminal circuit malfunction
DTC P0630: Vehicle Identification Number (VIN) malfunction
DTC P0638: Throttle actuator control motor circuit range/performance
DTC P0642: Throttle position sensor supply power
DTC P0657: Throttle actuator control motor relay circuit malfunction
DTC P0830: Clutch Pedal Position Switch Circuit Range
DTC P1021: Intake engine oil control valve circuit
DTC P1025: Exhaust engine oil control valve circuit
DTC P1231: Active stability control plausibility
DTC P1232: Fail safe system
DTC P1233: Throttle position sensor (main) plausiblity
DTC P1234: Throttle position sensor (sub) plausibility
DTC P1235: Mass airflow sensor plausibility
DTC P1236: A/D converter
DTC P1237: Accelerator pedal position sensor plausibility
DTC P1238: Mass airflow sensor plausibility (torque Monitor)
DTC P1239: Engine RPM plausiblitiy
DTC P1240: Ignition angle
DTC P1241: Torque monitor
DTC P1242: Fail safe control monitor
DTC P1243: Inquiry/response error
DTC P1244: RAM test for all area
DTC P1245: Cycle RAM test (engine)
DTC P1247: TC-SST plausibility
DTC P1320: Ignition timing retard insufficient
DTC P1400: Manifold Differential Pressure Sensor Circuit Malfunction
DTC P1506: Idle control system RPM lower than expected at low temp
DTC P1507: Idle control system RPM higher than expected at low temp
DTC P1530: A/C1 switch intermittent
DTC P1590: TCM to ECM communication error in torque reduction request TC-SST
DTC P1603: Battery Backup Circuit Malfunction
DTC P1676: Variant coding
DTC P2066: Fuel Level Sensor Circuit Range/Performance
DTC P2100: Throttle actuator control motor circuit (open)
DTC P2101: Throttle actuator control motor magneto malfunction
DTC P2122: Accelerator pedal position snesor (main) circuit low input
DTC P2123: Accelerator pedal position sneosr (main) circuit high input
DTC P2127: Accelerator pedal position (sub) circuit low input
DTC P2128: Accelerator pedal position sensor (sub) circuit high input
DTC P2135: Throttle position sensor (main and sub) range/performance problem
DTC P2138: Accelerator pedal position sensor (main and sub) range/performance problem
DTC P2195: Heated 02 (front) inactive
DTC P2228: Barometric pressure circuit low input
DTC P2229: Barometric pressure circuit high input
DTC P2252: Heated 02 sneosr offset cicuit low voltage
DTC P2253: Heated oxygen offset circuit high voltage
DTC P2263: Intake Charge System Malfunction
U0001: Bus off
U0101: TC-SST-ECU time-out
U0121: ASC-ECU time-out
U0141: ETACS-ECU time-out
U0167: Immobilizer communication error
U1180: Combination meter time-out
Old Nov 27, 2010 | 09:19 PM
RazorLab's Avatar
You flashed a Evo 10 52680015 ROM into a GTS Ecu?
Just curious
Old Nov 28, 2010 | 12:17 PM
criptballer's Avatar
did you recently do cams? or have you messed with the camshaft mivec sensor solenoid or solenoid cables? i've seen this before and there are a couple of possible factors for the p0365.
Old Nov 28, 2010 | 12:18 PM
dadsgts's Avatar
gts
yes i did. Other then those codes, it runs great. afr's are just about perfect and I'm not in limp mode as of yet and i put about 150miles on it so far. I run a complete evo x turbo setup on my car.
Old Nov 28, 2010 | 12:24 PM
so you did install cams recently? check your target to actual mivec on both intake and exhaust side. make sure they are within reason. meaning, if target intake is 10 it should be around 10ish, if exhaust target is 0 the actual should be around 0ish.
have you done a "wire tuck" of the cables going to solenoid sensors or antyhing of that matter?
update: ****, i just realized you said yes to the question, did you flash a GSR map to a GTS. Nevermind on my help. good luck. never heard of anybody doing that and i assume it can't be good.
Old Nov 28, 2010 | 04:34 PM
johnsahomo's Avatar
actually it kicks *** it just needs a decent tune. How many people can say that their gts with a check engine light can keeps up with Evos? PROOF: I was there
Hey John look at this when your at work tomorrow https://www.evolutionm.net/forums/ec...beginners.html , the cylinder trim isnt what u should be messing with; High Octane Map is in AFR Units look at where the light cruise light acceleration and WOT paths are. AND: https://www.evolutionm.net/forums/ev...ut-serial.html to Log AFR if you really need to; **** a professional tune
Old Nov 28, 2010 | 08:18 PM
Yeah until the gts and Evo turn a corner or better yet when the gts can't hook up on the front tires. But hey to each their own. Enjoy.
Old Jun 6, 2011 | 09:56 AM
popdakebin's Avatar
I just got this code after installing a hi-flow cat. Anyone know a fix? Any issues if I just leave it?
Old Jun 6, 2011 | 10:39 PM
xhomm02's Avatar
Yes - disable rear O2 sensor. Had the same problem with HFC.
Old Jun 7, 2011 | 09:06 AM
popdakebin's Avatar
How do you disable it? Tuner?
Old Aug 28, 2012 | 07:22 AM
evoe85's Avatar
I just got this code p2229 after my built..does anybody know whats this?
Old Mar 23, 2018 | 10:25 PM
jonmbaez's Avatar
bumping a really old post.
i have the same exact issue.
i turboed my GTS and i have evo X ROM any help on how to permantently patch those DTC?
did OP figure it out?
sebass007
Lancer How Tos / Installations
40
Dec 28, 2020 08:20 AM
DSMMR21
Nov 23, 2014 03:20 PM
DSMMR21
May 4, 2013 01:14 PM
corey54321
Feb 25, 2013 05:09 PM
hayaboosted
May 7, 2011 09:43 AM
