i can not read a evo X. Help
Old Feb 3, 2011 | 11:18 AM
fostytou's Avatar
EvoM Community Team
Originally Posted by raulhp
Tephra, i have read your post about bench the ecu
https://www.evolutionm.net/forums/ev...h-process.html
The log on the ecuflash when i try to read is
[23:15:44.000] sending init sequence 1 (0001)
[23:15:47.218] sending init sequence 1 (0003)
[23:15:50.437] sending init sequence 1 (FFFF)
[23:15:53.140] no response to any known code
[23:15:53.140] interface close
Is that log taken from an attempted read during a bench? If not, get it on the bench, read the rom, then send it to him...
Old Feb 3, 2011 | 02:09 PM
raulhp's Avatar
no, this is a the log when i try to read the OEM map with the tactrix cable with ecuflash
Old Feb 3, 2011 | 02:31 PM
Golden's Avatar
Do you have the latest drivers for your OpenPort 2.0 cable along with the latest EcuFlash?
I've heard of Evo 8/9 guys removing a pin on the cable for some reason. Yours does still have all the pins, right?
Old Feb 3, 2011 | 05:31 PM
tephra's Avatar
HOLD ON
Are you selecting Mitsu CAN 2007+ ? When doing the read
Or are you selecting old Mitsu cars?
Old Feb 4, 2011 | 01:20 AM
raulhp's Avatar
I installed the last version of ecu flash 1.43 and when it installs, the drivers were installed too
I have all the pins on my cable right now (version2.0)
Tephra, yes, i select Mitsu can vehicles... (better looking interface on the beta version)
it is very strange, because i read a CAN lancen 2.0 NA (143 Hp) car 3 months ago, I have had not the XML for this car, but i can read the map, then i got the XML and i tuned.
Old Feb 4, 2011 | 03:38 AM
tephra's Avatar
well its very strange..
bench it (ie remove from car) and send me the ROM for comparison vs a known stocker
Old Feb 4, 2011 | 09:59 AM
fostytou's Avatar
EvoM Community Team
That is for ACD logging. No pins need to be removed on OP2.0 ever... it can dynamically turn pins on / off if I understand correctly.
Old Feb 5, 2011 | 05:27 AM
raulhp's Avatar
finally i can read the ROM...the changes done were add to the ecuflash all the xml's for EVOX...
then i check and uncheck some options, open and close the program and VOILA
the rom is 53050006
FFEMT
Aug 1, 2016 04:45 AM
RA09
10
Feb 4, 2013 09:19 AM
monkeyevo
Jul 20, 2011 11:09 PM
csra09
Mar 5, 2011 03:49 AM
mexevo
Aug 13, 2007 12:43 AM
