question about tuning and going back to stock
Old Dec 4, 2011 | 11:22 AM
Subi.convert's Avatar
Question question about tuning and going back to stock
Can the dealer see that the car has been tuned if you flash a stock map back on the car before taking it in?
Old Dec 5, 2011 | 07:31 AM
Jookies's Avatar
There has been talk that there is a "flash counter" so the dealer can see how many times your ecu has been flashed. If this is true, or how easy it is to access if it is true IDK. I've never had a problem, though i've never done serious expensive damage to my car haha.
Old Dec 7, 2011 | 04:10 PM
Thanks for the reply.
Old Dec 8, 2011 | 04:49 PM
sailing217's Avatar
Not sure
Old Dec 17, 2011 | 01:11 PM
Wraiths_Zero's Avatar
yeah I'd like to know bout this too
Old Dec 21, 2011 | 03:14 PM
IceCold98GSX's Avatar
I will find out sometime in the next couple of weeks. I presented a good case to get my transmission warrantied for the center diff issue and they need to check the ECU for a flash.
Old Dec 21, 2011 | 06:31 PM
sirsol's Avatar
Based on what Tephra said here, there IS a flash counter:
https://www.evolutionm.net/forums/ev...g-counter.html
Now, I'm not sure what level of access an average tech has to this information at the dealership level. If push comes to shove and you go in for a new engine, Mitsubishi corporate can pull this information if necessary.
Old Dec 21, 2011 | 06:41 PM
UT_EvoX's Avatar
In reference to the "flash counter," I know for a fact that it is not accessible via the standard MUT-III interface. Whether the new MEDIC device dealers use can readily access it without sending a custom MUT command, I do not know.
Besides, who is to say you didn't swap among Mitsubishi-sanctioned flashes 100+ times They absolutely cannot prove what you flashed the car with, and they also can't legally force you into using a Mitsubishi dealership for service, so they can't get you on that avenue either.
I gave up on the whole Evo warranty thing a long time ago. You're screwed either way if you end up really needing the warranty to cover your butt for an expensive repair. They're going to blame you for abusing the car regardless of it being hopped up.
Old Dec 21, 2011 | 11:07 PM
Walter686's Avatar
__________________
Old Dec 22, 2011 | 07:18 AM
Trust me, I'm not counting on it getting warrantied. In the end I will probably get the abuse excuse like you said. Not a big deal to me, I'll just send it off to shep then. I'll check back if they saw the car has been flashed. I'm currently on a stock tune but it was previously tuned before.
UF_Evo
Jan 19, 2017 01:55 AM
k0lok0yboi
Mar 29, 2016 09:04 AM
tnn35
Cobb AccessPORT
Oct 11, 2013 06:04 AM
pbassist12
14
Mar 7, 2011 08:48 AM
DarwinX
12
Aug 4, 2009 03:57 PM
