EvoScan, boost, and Virtual dyno
Old Dec 6, 2011 | 12:58 PM
WarmMilk's Avatar
So I've been playing around with my VR lately and I can't seem to get it to show boost
here's a chart I logged with the EVOX CAN MUTIII setting in evoscan, but this setting doesn't have a "boost" log check box
obviously that boost curve isn't right
after PMing a member on here about it he suggested I try loggin in the "Mode23 US RA EVOX" setting, so I tried that and the "Mode23 US EVOX" setting, but when I try to import the log into the VR I get this
and yes, I made sure that it was logging the TPS...
anyone have any suggestions on how I can get a real boost log to show on the VR?
Old Dec 6, 2011 | 03:43 PM
jmorris1027's Avatar
Do you have mode 23 enabled in your car with ecuflash?
Old Dec 6, 2011 | 04:16 PM
WarmMilk's Avatar
yes (as I already told in in the PM )
Old Dec 6, 2011 | 05:55 PM
ScottSpeed21's Avatar
In Evoscan, under the 'Select ECU' drop down menu, you want to choose 'Mode23 EVOX USA'
Old Dec 6, 2011 | 06:45 PM
WarmMilk's Avatar
I tried that, and edited the OP for accuracy, but I didn't try "Mode23 2010 USA RA EVOX" like jmorris originally told me in the PM... (I have a 2011, so maybe thats why)
I'll try that tomorrow on my way home from work and see if it works. In the mean time if anyone else has any idea's I can try also, please post them
thanks
Old Dec 7, 2011 | 06:31 PM
WarmMilk's Avatar
tried it with the "Mode23 2010 USA RA EVOX" and I get the same no TPS data found...
anyone have any idea's?
Old Dec 7, 2011 | 07:57 PM
lanasa's Avatar
I can't log RPM for some reason.
Old Dec 10, 2011 | 01:47 PM
WarmMilk's Avatar
nobody has anymore ideas?
Old Dec 13, 2011 | 06:50 AM
mrfred's Avatar
mode23 relies on having the ram addresses of the items to be logged. 2011s likely have different addresses. what version of evoscan are you using? have you checked to see if golden has a set of addresses for the 2011?
Old Dec 13, 2011 | 08:53 AM
WarmMilk's Avatar
I have evoscan v2.8.0005 and I'm using golden's definitions for my rom ID
Edit:
Unless English changed it when they tuned my car...
Old Dec 13, 2011 | 09:50 AM
RazorLab's Avatar
You need the 2011 address for evoscan
Try either of these sets and see which one works correctly (There are a couple different 2011 logging address sets now)
Code:
238087A8 Load
23808780 2ByteRPM
23808752 PSIG / Boost
23808A87 Knock Sum
238088D4 STFT
23804573 LFTF Idle
23804575 LTFT Cruise
238088E5 LTFT in use
238087AE Load (MIVEC) and (Timing if IAT GT 75F)
23808731 TPS
23809625 Accel Pedel Position
23808A43 TimingAdv
23808B91 ActiveWGDC
2380868F Intake Air Temp
23808673 Coolant Temp
23808695 Manifold Air Temp
2380AB1C IPW
23808FA4 MAF Volts
23809546 INVVT (Target)
23809552 EXVVT (Target)
2380957E INVVT (Actual)
2380958A EXVVT (Actual)
23808823 Speed
23808727 Battery
2380AAE1 Barometer
23808A8D knock_adc_processed
2380AB13 knock_base
2380AB0F knock_var
2380AB15 knock_change
23808A9B knock_dynamics
23808135 knock_flag
238086A1 Front O2
238086A5 Rear O2
238045C5 Cruise Light
23808B8F WGDC Correction
23808817 MAF Hz
Code:
238087B4 Load
2380878C 2ByteRPM
2380875E PSIG / Boost
23808A93 Knock Sum
238088E0 STFT
23804573 LFTF Idle
238088F1 LTFT in use
238087BA Load (MIVEC) and (Timing if IAT GT 75F)
2380873D TPS
23809631 Accel Pedel Position
23808A4F TimingAdv
23808B9D ActiveWGDC
2380869B Intake Air Temp
2380867F Coolant Temp
238086A1 Manifold Air Temp
2380AB40 IPW
23808FB0 MAF Volts
23809552 INVVT (Target)
2380955E EXVVT (Target)
2380958A INVVT (Actual)
23809596 EXVVT (Actual)
2380882F Speed
23808733 Battery
2380AB05 Barometer
23808A99 knock_adc_processed
2380AB37 knock_base
2380AB33 knock_var
2380AB39 knock_change
23808AA7 knock_dynamics
23808135 knock_flag
238086AD Front O2
238086B1 Rear O2
23808B9B WGDC Correction
23808823 MAF Hz
Old Dec 13, 2011 | 12:44 PM
WarmMilk's Avatar
I appreciate the help but honestly I have no idea what to do with that... I originally followed a how to thread on the other forum to enable mode23 but I can't find it anymore to reference it... if I send you my .hex file or .xml file or whatever file you need, do you think you can put the info in for me so all I have to do is reflash my ecu? I'm willing to compensate you for your time.
Old Dec 13, 2011 | 02:03 PM
RazorLab's Avatar
Those are logging address's for Evoscan.
Go to C:\Users\Yourusername\Documents\EvoScan\DataSettin gs\Mitsubishi EvoX Mode23 USA.xml
Open that XML file, then add a section in there that looks like this, before the /vehicle tag
Code:
 <ecu name="Mode23 2011 USA RA EVOX">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="23808780" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="238087A8" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A43" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AAE1" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="23808752" Eval="(x/4*0.1953125)-[Baro]" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A87" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="23809625" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="23808731" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808B91" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AB1C" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="23808695" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="2" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808673" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="2380868F" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="23808823" Eval="x*1.243" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088D4" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088E5" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="238086A1" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="238086A5" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="23808727" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809546" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="23809552" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380957E" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="2380958A" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808FA4" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Airflow" LogReference="MAFgs" RequestID="23808FA4" Eval="x*0.02" Unit="gs" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
      </Mode2>
    </ecu>
Old Dec 14, 2011 | 06:59 PM
WarmMilk's Avatar
so if the this doesn't work, I replace the "RequestID" with the addresses in the second set?
after looking at it, looks like the set you gave me in the post above is the first set of addresses, correct? so if it still doesn't work with that I need to update all the addresses with the second set?
(yes, I know how much of a n00b I sound like...)
Old Dec 14, 2011 | 08:52 PM
WarmMilk's Avatar
it worked!
thanks for the help
WarmMilk
Northwest Region
Apr 19, 2014 03:51 PM
WarmMilk
Mar 15, 2012 06:20 AM
WarmMilk
Jul 26, 2011 09:41 AM
WarmMilk
Apr 3, 2011 05:07 PM
WarmMilk
Northwest Region
25
Nov 2, 2010 01:12 PM
