Is this safe to run with just an intake and exhaust?
Old Apr 18, 2012 | 09:45 AM
initialdrew's Avatar
THANK YOU MOD FOR REMINDING ME ABOUT THE LINK OF THE FLASH!
Hello all, I did this flash to my car (I have a apexi intake and greddy TiC catback exhaust)
Grande (more aggressive):
Evo X GSR 91OCT: LINK BELOW
http://www.evoxforums.com/forums/att...4&d=1257870584
These ROMs are targeted at users with none - to - light modifications. If you have a less restrictive drop-in filter, watch your afr's.
Boost: Modified boost to run slightly higher(improved breathing) should taper to 17-18psi versus stock
Fueling: Fuel reduced 10+ %
Timing: Timing is increased up to 5000rpms and then reduced up top.
More boost / leaner / slightly more timing than GENERIC
Mivec: Mivec is modified JDM.
Is anybody else running this flash? thanks!
Old Apr 18, 2012 | 03:27 PM
Anyone here that could answer me?
Old Apr 18, 2012 | 03:36 PM
Sidnakit's Avatar
"I this flashed to my car"
Old Apr 18, 2012 | 06:47 PM
LOL sorry typed it on iphone....didn't even check
Old Apr 19, 2012 | 06:29 AM
stokEd's Avatar
It sounds like you don't know what you're doing, so no, it's not safe.
Old Apr 19, 2012 | 06:36 AM
stokEd's Avatar
And do you have a log for us to look at it? Are you monitoring your AFRs? What about boost?
Old Apr 19, 2012 | 10:58 AM
fostytou's Avatar
EvoM Community Team
This.
As I said in the PM - please provide more details or no one can help you. No one know what map, tuning software, or anything else you are talking about.
"Anyone here that could answer me?" is not details.... seems more like a bump.
Old Apr 29, 2012 | 08:34 AM
momostallion's Avatar
gunzo's 91 octane map?
he says "If you have a less restrictive drop-in filter, watch your afr's. "
you have an intake and a catback exhaust so the assumption is your air fuel will be a bit more lean than his target.
you would need to datalog this and you will need a wideband o2 sensor if you want to do it right.
moparfan
Mar 18, 2021 10:28 PM
PIE-R
Dec 21, 2019 08:14 PM
boy36
Dec 31, 2007 03:54 PM
AMS
Automotosports - Illinois
94
Sep 24, 2006 10:15 AM
ShiftySVT
Aug 14, 2006 06:39 PM
