My car died while idling.. ????
Old Nov 7, 2012 | 08:57 PM
Oziel's Avatar
I installed the ETS intake on my EVO X and I didn't put a tune on it, because I read threads saying it was okay to do so. I just sat in my car for 10 mins and died on me 3 times.. Do you think it's because I need a tune?
Old Nov 7, 2012 | 09:02 PM
XTR Performance's Avatar
Same exact thing happened to me except I was driving while it stalled. I am on the stage 1 cobb tune... I am honestly not sure what caused it but it didn't happen again after the first time...
Old Nov 7, 2012 | 09:12 PM
Oziel's Avatar
Yah I'm really confused, my friend told me not to put it on until I got a tune. I'm just hard headed and put it on. Now I gotta get me my aem uego and a Michael golden tune until I can drive my car again... Great
Old Nov 7, 2012 | 09:30 PM
Well you do have a 2008 Evo X so you should be fine. Just stay out of boost. The 08s had the richest tune from factory.
-Chris
Old Nov 8, 2012 | 08:10 PM
Octane Blue's Avatar
Did you check for vacuum leaks? Shouldn't die, especially when you take into consideration that the ETS intakes use the OEM MAF housing (last time I remember).
Old Nov 9, 2012 | 07:15 PM
Golden's Avatar
ETS shouldn't need a tune, as it uses the stock MAF housing.
You probably have a leak. A post MAF leak will cause the car to idle like crap.
Old Dec 6, 2012 | 12:05 PM
GeeDubz's Avatar
I know this is an old post but perhaps others can benefit from my experience.
If you change back to the stock map and the problem goes away, it's the map. If it's still stalls like the problem I had, it was a vacuum hose on the bottom left of the top of the engine about 7 o'clock position if you were standing in front of your car looking at the engine. Don't know why that stock vacuum hose was keep coming off for me so I bought another length of vacuum hose to replace it and it hasn't come off since.
Old Dec 6, 2012 | 02:01 PM
fostytou's Avatar
EvoM Community Team
The FPR line? Common problem, but I doubt that's what happened here...
Tehjoser
18
Feb 15, 2025 01:49 AM
J Woody
Jan 11, 2014 07:02 PM
Babs
Jul 11, 2013 06:42 PM
fjm9898
Dec 1, 2012 05:17 PM
04WhiteRalliart
Apr 5, 2007 03:06 AM
