AP bricked my ecu
Old Apr 5, 2014 | 05:42 PM
Sj119808's Avatar
damn thats scary. good luck! id say get it tuned to stock at mitsubishi then go from there
Old Apr 7, 2014 | 01:12 PM
alsong2002's Avatar
i am already back to stock tune and now saving money to put all mods back to the car then have Beeble for Etune
Old Apr 7, 2014 | 03:42 PM
JohnBradley's Avatar
The $100 is what they charge Pro-Tuners. In reality there is always a cause and effect though when they brick. Anything out of the ordinary when it did it? I have never had an AP brick a X, so I am not sure on that, but on the opensource its usually either a low battery or bad cable.
It seems anyway.
Old May 18, 2014 | 12:38 PM
EvoXHeidi's Avatar
Originally Posted by alsong2002
my tunner was tuning my car today, and everything went fine. after that we saved the map in cobb AP and tried to flash it to my car, however the AP dead/frozen in the middle of flashing. then my car wont turn on and he said the ECU might bricked because of that. my tuner immediately switch to opensourse and unbricked the stock map back to the ecu (thx god the car is runing again). we called cobb and ask to send in the AP for repair. in this case do i also have to send in my ECU too?
what do you think its the cause of this kinda thing happens? is the tuning itself or is the cobb device.
will it be happen again if we try to flash the new tune after it got fixed?
Same thing happened to me except I was using an OTS map. It sent the car into limp mode. But, after i turned the car off it would't start again. I had to remove my ECU and send it to COBB to unbrick it. I got it back and when I went to flash a map it bricked again. I sent it to COBB who benched it again but this time when I got it back it wasn't working at all. I had the car towed to Mitsu dealer and they got a new ECU covered under warranty somehow. Haven't had any problems since however I am onto open source now.
MindGamez
Aug 24, 2016 09:19 AM
CanEvoX
May 22, 2016 09:41 PM
t3am 83rd
Cobb AccessPORT
Apr 28, 2016 08:16 AM
50joe
Cobb AccessPORT
Dec 11, 2015 05:15 PM
crankIT
Cobb AccessPORT
14
Sep 14, 2011 09:57 AM
