ecuflash
Old Sep 5, 2019 | 07:07 PM
hdievox's Avatar
ecuflash
new to ecuflash and really need help was able to find my romid but cant read or edit anything my tuner wont help me learn
Old Sep 5, 2019 | 08:11 PM
RazorLab's Avatar
Influx of these same questions. READ THE FORUMS. All the info is right there for you. Stop being lazy people.
Old Sep 5, 2019 | 09:16 PM
hdievox's Avatar
I’m not lazy. I’ve searched and searched That’s how I was able to find the rom Id. My tuner made it so I can’t read the maps I’ve tried hex edit I can’t figure out how to convert it to a hex so I can edit in EcuFlash
Old Sep 6, 2019 | 01:25 PM
Metal_AF's Avatar
Did your tuner use an AccessPort to do the tune or something?
When you open ECUFlash and connect to your car with the tactrix, are the buttons at the top greyed out or are the colored arrows there?
Old Sep 6, 2019 | 05:26 PM
hdievox's Avatar
Ok. My tuner used EcuFlash And yes I can pull the rom I just can’t read it. It’s like he hid the maps or something. I was able to figure out my Id which is 58010105. And yes I know that’s a tephra mod. Sometimes you just need help
Old Sep 6, 2019 | 06:03 PM
Metal_AF's Avatar
Ok, I might have ran into the same thing you are describing here. When I first got my car from the dealership, I was able to access my tables, and I configured mode23 logging. About a month passed and I took the car to the dealership for the first round of maintenance and there was a recall or a TSB on the ECU(2011). They asked if I wanted them to go ahead and update it. Without thinking about it, I told them sure. After that, I hit the problem you are running into, and mode23 stopped working too. When I would try to pull down the table, it couldn't identify the rom id anymore, and wanted to try to use "inherited" values. In the end I din't get it working until I moved over from tephra v3. Once I was on v3, I was able to get to my maps again.
Old Sep 7, 2019 | 06:54 AM
crimson red's Avatar
If you don't have a definition for 58010105, ecuflash cannot show maps of 58010105.
Have you installed a definition for 58010105 into your ecuflash's 'rommetadata/mitsubishi/evo/' folder?
Old Sep 7, 2019 | 01:24 PM
hdievox's Avatar
Ok thank you all the info. I will eventually buy the v3 But for now I want to be able to see the maps first. I can’t find the definition for 58010105. I did inherit it to 5800005 but still. Nothing. I also tried to copy to that def Is it possible to just start fresh?
Old Sep 10, 2019 | 03:49 AM
Have you read my PM(Private Message)?
Old Sep 12, 2019 | 09:50 AM
azimx7's Avatar
hi. crimson red. will u be able to help me sort some things with ecuflash?
Old Sep 14, 2019 | 12:45 AM
PMed to your PM to me.
joshl'sevo8
Mar 30, 2010 06:54 PM
EVOXTIMES
Jan 15, 2010 02:57 AM
ThunderOZ
Lancer Engine Management / Tuning Forums
Aug 6, 2008 05:05 PM
mymigi
Jun 15, 2008 02:10 AM
Tuky
Jan 15, 2008 04:52 AM
