Will Installing a CAI be a bad choice for one of my first mods?
Old Dec 12, 2019 | 09:41 PM
frostlord's Avatar
I know this has probably been asked a million times before but I couldn't find any threads that were helpful.
I'm planning on purchasing a few affordable mods for my Evo X MR just to start off with. I have already purchased a Catback exhaust and was considering a AEM Cold air intake because I like the design and they seem really easy to install.
But I've heard some people saying that they gained power after installing while other people say that they lost power and it's better to just keep the stock airbox.
My question is, will I get any power gains from installing the AEM CAI and getting a tune or should I stick with the OEM Airbox?
Old Dec 13, 2019 | 02:54 PM
bmxhotsauce's Avatar
you need a tune for an intake. Not worth it unless your car is going to be tuned for it.
Old Dec 13, 2019 | 10:21 PM
frostlord's Avatar
When I install the intake I do intend to get it tuned. Hopefully that will result in me gaining some power
Old Dec 14, 2019 | 11:37 AM
whtrice's Avatar
Veteran: Air Force
Just a tune (from a decent tuner) would do that even with out an intake.
Old Dec 17, 2019 | 01:29 AM
frostlord's Avatar
So getting an intake would be a pointless waste of money?
I should forget about the intake and keep the factory airbox?
Old Dec 17, 2019 | 05:49 AM
jayevo23's Avatar
I had the AEM CAI on my 08' without a tune and didn't run into any issues. If I were you, my next mod would be a high flow cat, UICP and lastly a intake plus tune in that order. I think the high flow cat is one of the best bang for the buck mods you can get on these cars.
Old Dec 17, 2019 | 11:30 AM
whtrice's Avatar
Veteran: Air Force
I never changed my intake on my IX RS (Just added a cone filter) for up to 417 whp. Tuned on E-85
Old Dec 17, 2019 | 07:52 PM
RazorLab's Avatar
The 10's are a bit different because they are hybrid MAP + MAF and run out of resolution at higher airflows. Of course, as a first mod, that isn't on the list of things that can happen.
Old Dec 17, 2019 | 11:36 PM
frostlord's Avatar
Thanks mate, I think I'll do just that. I already have a catback on order so next is the UICP
Old Dec 20, 2019 | 08:36 PM
crimson red's Avatar
What you need to do depends on what you are intending to.
If you want to get more power, The first thing to do is to tune your ignition timing and boost up. For light tunes, a stock turbo is sufficient. If you want more power, you should replace your stock turbo to bigger one. After replacing your turbo, If the intake air is insufficient, replace your air intake to larger one.
If you want to just dress your car up, install any parts as you like.
Old Dec 22, 2019 | 01:27 AM
frostlord's Avatar
Thanks, eventually was going to upgrade to a bigger turbo but just starting out with some easy more affordable mods.
1012Xmr
Sep 8, 2012 09:00 AM
weetinyway
Jun 7, 2012 04:29 PM
jirro22
42
Dec 6, 2010 12:32 AM
Psycho09RA
29
Dec 17, 2009 10:01 AM
tnhockey
14
Oct 11, 2007 06:18 PM
