Evo X MR, can u upgrade the clutch?
Old Mar 13, 2009 | 02:31 AM
  #121
Yousef's Avatar
Originally Posted by triso
i just want to let you guys know you have another customer when these clutch packs get made.
+1
Old Mar 13, 2009 | 10:24 AM
  #122
Chebosto's Avatar
is there a transmission oil cooler that you can insert or plumb into this to reduce oil temps and thus reducing the chance of the car going "Slow Down" or giving the "red screen of shut off death?"
maybe through the drain hole, plug a switchable pump like they do for differential coolers?
Old Mar 13, 2009 | 10:27 AM
  #123
salukidude's Avatar
^ There is a post somewhere, maybe a different forum, where this guy takes out the fog lights and replaces the left one with a fan that points right at the cooler. Looked like a good idea.
Old Mar 13, 2009 | 10:31 AM
  #124
Webman's Avatar
I remember reading that... I think, in fact, there are others saying all you have to do is remove the fog lights...
  #125
JEFFREYCASTGSX's Avatar
Supposedly Sheperd was already working on upgrading these trannys.
Old Mar 13, 2009 | 11:38 AM
  #126
Chebosto's Avatar
here are images of the GTR transmission cooler that is under development.
http://www.gtrblog.com/index.php/parts/willall/?blog=4
if we do a similar methodology. perhaps we can get something for our SST to stay cooler during hotter operating temperatures... (thermobaric opening at X*C like oil coolers do.) we can run the power up higher w/o the shut off warning.
this is a prototype GTR sump pan..
Willall Racing are taking a different tact in the field of transmission cooling. While thus far the GT-R’s GR6 dual-clutch transmission has been adapted to external cooling via a simple billet adapter and radiator, Willall have taken to engineering an entire sump replacement and more.
We’ve only been given details on the GR6 sump replacement so far so lets dive into what we know.
The Willall Racing Transmission Cooler (WR35TC) comes with an anodised billet aircraft quality aluminium transmission sump. The computer modelled and 5-axis CNC’d sump is deeper than the standard sump allowing for a larger oil volume. The WR35TC sump is also finned allowing for a much larger surface area for heat to both transfer out of the oil and for air to then carry that heat energy away.
The WR35TC provides removable access ports to give access to the transmission magnets which should be cleaned during a transmission service. It also bolts straight on using the OEM gaskets.
This is part one of the cooler, the primary cooling mechanism is yet to be revealed. To see what heat exchanging path they will follow check back soon when we have part 2 of this report.
Old Mar 13, 2009 | 12:03 PM
  #127
LVSBB6's Avatar
ARC, Blitz & HKS are all working on one.
Old Mar 13, 2009 | 04:06 PM
  #128
philamthebest's Avatar
i too am doing a lot of modding to the sst this summer, i have had no problems yet, but when i install the cams and turbo i will let you know, i am aiming for 450 and calling it a day.
Old Mar 18, 2009 | 12:51 PM
  #129
Phantom09's Avatar
im waiting as well... whoever gets these trannies to hold 400 or over i will be a customer..
Old Mar 25, 2009 | 09:13 AM
  #130
svt04cobra's Avatar
The over is key!!! I want to make 700 on low boost and 800+ on high.
Old Mar 25, 2009 | 09:42 AM
  #131
TTP Engineering's Avatar
700-800whp is just as likely as the upgraded clutch assembly to be released for the SST.
Not...
If something is released for the car, expect it to come from HKS.
Old Mar 25, 2009 | 09:00 PM
  #132
evoseller888's Avatar
Oh
Old Apr 5, 2009 | 12:33 PM
  #133
pcasupreme's Avatar
i really hope they make something soon, im itching to put mods onto my MR :/
Old Apr 6, 2009 | 09:54 AM
  #134
svt04cobra's Avatar
+1
Old Aug 3, 2009 | 03:24 PM
  #135
ResourceX's Avatar
Originally Posted by supersilverMR
And the problem with over heating can be helped by placing a 10'' Spa fan directly behind the tranny and splicing the cut-on/off wires into the dual fan located behind the radiator. Ill take some pics of this to help if needed.
Look up Vorschlag for their upgrade on the overheating. It works and is much simpler then you are stating. I've done the mod and can assure all with the SST that it works.
Resourcex
