EVO X TURBOS , What has the titanium ?
Old Sep 30, 2008, 10:54 AM
jarkko's Avatar
so my question is :
TD05H-152g6-12t 49378-01631
or
TD05HA-152g6-12t 49378-01610
are those both with titanium wheel or not ?
Old Sep 30, 2008, 11:18 AM
jarkko's Avatar
and one more thing..
could I chance the 12 t to some older model 9.8 for example ?
I would like to have ultimate spooling and still good power.
about 350-375hp at flywheel .
Old Sep 30, 2008, 12:37 PM
Thegame's Avatar
Originally Posted by jarkko
so my question is :
or
The TD05H is Inconel and an aluminum alloy. That's what's on our cars, I think. The TD05HA is Titanium and I think it is on the RS in Japan, or is going to be.
Old Sep 30, 2008, 12:39 PM
Thegame's Avatar
I doubt that part would just bolt up to your X. First, the O2 housings and exhaust manifolds are different on our cars. Second, the VIII's and IX's were reverse spinning turbo's. Plus, a 9.8 would be a step backwards. The X spools great already, no need to choke it in the higher rpm's.
Old Sep 30, 2008, 07:35 PM
gunzo's Avatar
Don't know about USDM / EUDM ..
but on JDM cars .. this is the weird part ..
the RS gets the inconel TD05H
the rest of the cars get the TD05HA
You can just check the turbo .. its easier this time round to see
Old Sep 30, 2008, 10:20 PM
jarkko's Avatar
well the real reason for me .
that turbo is coming for fiat, not evo ...
my project car is 2.0 16v coupe turbo.
doesnt the evo 9 and x have already somekind of help at spooling, because of the chancing cam settings or something like that ( sorry my bad english )
I dont have those helps on my car, so how good would that 12 T turbo spool, or should I go for evo 6.5 TME turbo ?
Old Sep 30, 2008, 10:41 PM
jarkko's Avatar
and for the spooling part, that I want :
full boost ( 20-21psi ) around 3000rpm at 4th gear . is that evo x turbo good for that, or should it be with smaller exhaust housing ?
Old Oct 1, 2008, 04:38 PM
Hiboost's Avatar
The stock Evo X turbo spools to 20 psi by 2700 rpms in 4th gear for me just for reference.
Old Oct 2, 2008, 04:32 AM
jarkko's Avatar
that sounds good
if using older car, like evo 8 or something, that doesnt have all those helps for the spooling, could it be around 3000rpm and 20psi ?
Old Oct 2, 2008, 12:19 PM
Thegame's Avatar
If you got that info from Turbo magazine, it's incorrect.
Old Oct 2, 2008, 04:47 PM
gunzo's Avatar
Did you see this info on any of the magazines then ??
This is direct from mitsubishi ..
Abec777
Jan 16, 2017 07:25 AM
M-A-T-T
12
Dec 15, 2016 09:06 PM
scheides
Oct 14, 2008 09:28 PM
Robevo RS
Sep 6, 2008 02:10 PM
SatansRectum
Future Lancer / Evo Models
17
Oct 1, 2007 04:25 PM
Quick Reply: EVO X TURBOS , What has the titanium ?
