Evo X bolt on Garrett GT30R turbos
Old Jun 6, 2009 | 12:16 PM
  #436
Boostd4's Avatar
Originally Posted by Hiboost
So it looks like some turbos are having issues, what doesn't make sense is that if the hotside is unbalanced due to size then why isn't it effecting all of the turbos? Are you saying unbalanced due to compressor to turbine wheel ratios (which seem similar to other GT30 setups) or unbalanced due to the relatively large hotside housing compared to the compressor side?
I guess the only way I can see these turbos lose power due to design would be dropping way below the 58% efficiency islands somehow due to some strange pressure dynamic. You would think having a larger than normal turbine side would be similar to having it ported a little big and would expect the top end performance to be better with some more spoolup lag induced, not reduced power and inefficient boost.
Boostd4: I noticed you had no upgraded O2/Downpipe piece but you wouldn't think reduced flow out the exhaust side would cause this much trouble with the turbo's output.
Maybe a casting flaw inside the turbine or compressor side is blocking flow? It's the only other thing I can think of that would destroy efficiency at higher flow levels. That is besides the wheels being out of balance in some way or not flowing correctly with the housing design.
Finally is there any way of telling if your turbo is going to be "good" or "bad" before installing it?
Actually, I have the AMS O2/DP upgrade. It was installed at the same time as the turbo...should be more than sufficient flow in combination with a test pipe and the GReddy cat back.
With regards to the concerns around the designs. Others have reported flow mismatch situations with Garrett GT30s on Evo 9s (yes different I know..but similar experiences). In that case it was the housing that was the issue. I do not know as of yet how it was resolved...but it seems consistent with what is going on with my turbo.
Honestly, if I were you I'd hold off on installing the turbo until some of this gets sorted out.
Old Jun 6, 2009 | 03:37 PM
  #437
evo400's Avatar
Registered User
Originally Posted by Boostd4
If it was a limited run, why would they allow units to get to consumers before going into full production? I was able to get one quite easily through one of their normal distributors. Hell, it's the splash screen on their website, anyone can get one if they want to! There are a few vendors that have posts in the for sale section right now with these turbos...
It would have made more sense to let just a beta group test the turbo. Some of the companies "testing" this turbo haven't even tuned it yet, even though those same companies are reporting shining success.
Please post whatever info you have of this car on a dyno...because honestly you are the first person to have mentioned any type of success with this turbo. If you can back it up with any kind of dyno data, my faith will be at least somewhat renewed.
Already posted a dyno plot some pages back .I can assure you there is not a single unsold unit out there with any vendor ,get on the phone and go try by one !. The first batch was allocated before it even hit the trucks !!! The turbo is fine and works awesome along with low turbo speeds and low back pressure numbers that all point to one bad *** turbo from Garrett .
I have a turbo speed vs rpm jpeg on the other laptop ,let me go find it !
Old Jun 6, 2009 | 04:45 PM
  #438
Boostd4's Avatar
https://www.evolutionm.net/forums/ev...-shipping.html
https://www.evolutionm.net/forums/ev...eady-ship.html
I guess I'm just not understanding what you're saying. I've had this turbo since late April as well as others. I'm sure the very first batch went quick, I was one of the buyers. Several vendors on other Evo boards have been selling these for well over a month and a half. I also know that the distributor that drop shipped my turbo has several on shelves. It's not like it is JUST NOW being released and impossible to get. According to the links above a phone call and a credit card can net me one at any time.
I guess I'm also confused by your turbo speed and low backpressure graphs...what is this really telling us? Was this performed off of the car? I'm sure that if your car is doing just fine you must have had the car on the dyno at some point...where are those graphs?
I think that the bigger issue is...where are all of the success stories if this is such a great turbo? I think the week the Dom2 and the FP hit the streets most of the well known tuners were all over those turbos. Why is it that no US based shops have come to redeem this turbo? Why is it that no one is chomping at the bit to test this thing? Do they know something that us lowly consumers don't?
Old Jun 6, 2009 | 05:07 PM
  #439
heavyD's Avatar
So the people here that have installed them have problems with the turbos not making power and a few people/vendors saying that there's nothing wrong with them and there are a bunch of cars running around with these turbos making big power with no problems except no dyno charts to back it up nor have any of these people chiming in to note their success. The only conclusion I can draw from reading this thread is that these turbochargers are $2K paperweights.
Old Jun 6, 2009 | 05:32 PM
  #440
Boostd4's Avatar
Speaking only for myself...exactly correct.
Old Jun 7, 2009 | 10:36 AM
  #441
evo400's Avatar
Registered User
Boostd4 back on page 23 is our dyno plot . Just reading about your problems . In case's like this its sometimes best to go backwards to reset the data you guys have . Replace all the stock stuff you have and baseline the motor. Hopefully this will raise a problem for you and you can move forward once you determin the problem .
Just for your info we used a M800 ECU with 3000 bucks of sensors on the car with exhaust back pressure Garrett turbo speed sensor on the compressor wheel ,intercooler pressures temps etc etc . We installed the sensors on the base car with stock turbo etc etc so we can see exactly what the car has done and why . The turbo speed on the Garrett is actually lower than stock ! the exhaust backpressure is also less than stock . We have the awesome Deatschworks 800cc injectors in there too!
Good luck .
Old Jun 7, 2009 | 11:15 AM
  #442
Boostd4's Avatar
Good luck .
Unfortunately, it seems like the turbo is the issue. With the exception of basic bolt on's, the car is stock. If anything, the bolt ons should help the turbo make power more than anything else. We've already gone through a battery of tests on the car...last test is looking at the turbo itself.
And before it even comes up...I'm dealing with probably one of the most well known and respected tuners in the US...
More than likely I'll be yanking the Garrett out this week and putting in a Dom2. My prediction...the car will make plenty of power.
And you still didn't answer my questions...where are the success stories and maybe some vids of your car on the dyno? Your responses are just like the distributors I've spoken with...smoke and mirrors.
Old Jun 7, 2009 | 11:25 AM
  #443
evo400's Avatar
Registered User
If its a turbo fault I would be suprized . No mirrors here as we tested independant of Garrett . This is why we fit so much data equipment so we know what is actually going on ! .If a turbo is Trash we spot it almost first couple of runs !
Good luck with the quest .
Old Jun 7, 2009 | 04:07 PM
  #444
DepoRacing's Avatar
I call bs, post a vid of it in the car then walk around get in and give us a pull.
Old Jun 7, 2009 | 05:05 PM
  #445
TTP Engineering's Avatar
In the video there has to be your mother, a police officer, a pastor, a prostitute and a painter all giving the thumbs up. Then he will believe you.
Old Jun 7, 2009 | 05:15 PM
  #446
lethalvenom's Avatar
haha lol
Old Jun 7, 2009 | 05:23 PM
  #447
SiC's Avatar
SiC
Dom2 = Great choice, I currently have one in my car. Be sure to back off the wastegate accuator spring since the initial preload is set to about 27psi and it holds to redline. I adjusted the preload to have initial 24psi so it gives me more room to play with.
I also have a GT3076 sitting as a big paper weight......
Old Jun 8, 2009 | 08:45 AM
  #448
Boostd4's Avatar
So I'm going to start the process of trying to reclaim my money for the Garrett today...have you even installed the Garrett yet? What are your plans?
Part of me is thinking that I should wait...but for how long?
Old Jun 8, 2009 | 09:35 AM
  #449
JayDub514's Avatar
Man this turbo had so much potential, especially with the amount of time they spent supposedly in R&D. I honestly expected a lot more from Garrett.
Old Jun 8, 2009 | 09:42 AM
  #450
Hiboost's Avatar
If my ETS tubular exhaust manifold reaches me on Friday I'll take a crack at the install this weekend instead of the following one. Big props to Michael at ETS for being the only one to come through on getting this upgrade shipped out so quickly after being ordered and built!
The fuel pump install went smoothly last night and I'll dial in my 800cc injectors Tuesday or Wednesday so I can fully test everything is ready to go. I'm going to be wrapping the tubular manifold and O2 Downpipe with that new Titanium heat wrap. The turbo will be wrapped in a T3 Titanium Turbo shield kit with a little modification. This should keep underhood temps in check and from what I've seen so far on other cars, this lava rock titanium heat shield stuff really works well from DEI.
