HKS SSQV Recirc Throwing LIMP MODE HELP!
Old Dec 16, 2008 | 09:26 PM
hurstnova350's Avatar
Angry HKS SSQV Recirc Throwing LIMP MODE HELP!
So I had HB Speed throw in the HKS SSQV set to Recirc along with an ETS Intake, ETS FMIC, Forge WGA, full T1R TBE, and Cobb AP w/Protune, but the SSQV is throwing the car in Limp Mode as well as the Check Engine Light. Im going back tomorrow and they want to throw the stocker back in to see what happens. I know there are members on here running this with NO issues.......Any suggestions, Please HELP???? **CEL is P1235**
Old Dec 16, 2008 | 09:34 PM
hopper's Avatar
reset ur ecu?? other than checking for boost leaks. Pull the code its throwin
Old Dec 16, 2008 | 11:10 PM
CEL is CODE P1235 ...any feedback?
Old Dec 16, 2008 | 11:18 PM
JoeyM3's Avatar
it's an overboost code, probably the forge wga, the bov will not cause the car to overboost so it's not the bov
Old Dec 16, 2008 | 11:59 PM
hopper's Avatar
Bingo. if boost is the same reset ur ecu. and you should be set
Old Dec 17, 2008 | 04:06 AM
Mad_SB's Avatar
Not the BOV, you changed at least two other things that would affect the load the ecu see's (ETS Intake and Forge WGA). Since the Ecu's "check" maps are load based as is the boost control, it's most probably one of those two things causing the limp mode and CEL.
Old Dec 17, 2008 | 04:19 AM
xXEvilMRxX's Avatar
bingo
Old Dec 17, 2008 | 04:38 PM
thanks guys, i will pass the info to my shop, i knew the BOV was not the issue
Old Dec 17, 2008 | 04:45 PM
everytime I reset the ECU, it just keeps coming back up
Old Dec 17, 2008 | 04:55 PM
Yearlongstorm's Avatar
I been having those similar problems but i really don thimk it the bov. I have the same one. The code will probably say something about fuel mass air flow or something like it.
Old Dec 17, 2008 | 08:01 PM
EVOXSILVER's Avatar
Hi,
I have excatly the same problem but only on part throttle. Just as MAD_VIII said it's because you are boosting too much compare to what the ECU is expected to see on a certain load.
It happens to me the day i've installed my HKS EVC 6 EBC. I cannot fix the problem right now because it's all about tuning the car properly. I think you might ask HB Speed to have a look at your boost/load map.
For now what i do is to run the car at 10% throttle or WOT or i turn off the EBC when my wife drives the car
Old Dec 17, 2008 | 09:01 PM
hel_if_ino's Avatar
For your information, after extensive troubleshooting on my car due to partial throttle overboosting, myself and Mike at Road Race Engineering narrowed the problem down to the blow off valve. Once we put the stocker back in all was well.
The reason being is these aftermarket bov's are more aggressive, allowing for a slightly quicker spool up earlier in the rpm range, but these cars don't like that and you will throw the limp mode over and over again.
My suggestion is this, take out the bov, put the stocker back in, don't do anything else and see what happens.
Old Dec 17, 2008 | 09:20 PM
BlueoctaneevoX's Avatar
Have a Agency Power BOV. It throws my car into limp mode. Threw the stocker back on and no problems.
Old Dec 19, 2008 | 05:44 AM
Joe's Evo X's Avatar
I didnt know the HKS SSQV can be set to Recirc
Old Dec 19, 2008 | 12:38 PM
shyong's Avatar
Same here. I have it set on 50/50 and haven't had any issues in the last 7 months I've had it. Did you set your BOV to 100% atmospheric?
MadBoost23
Lancer Engine Management / Tuning Forums
Jun 10, 2015 11:57 PM
MyEvo8Urs
Apr 18, 2012 09:45 AM
Inflation
Aug 22, 2008 06:37 PM
Subur_Who?
Dec 13, 2006 10:28 PM
ecmotorsports
Feb 27, 2006 09:11 PM
