Tranny gone (manual)
Old Mar 31, 2009 | 02:14 PM
  #31
markmec78's Avatar
My car had the same fault (thread on here)
I have been speaking to a few people, it seems there are a few opinions of how and why??
The original oil has been suspected...
Also manufacturing tolerance's possibly too tight on the diff, and as such under hard cornering, of full lock and full throttle theis is where the diff is working it's hardest.
It is the center diff which is failling and there is no concrete evidence just theories??
I have asked on my thread for anyone who has had a failure to please contact me with some details..... ( please see my thread for whats needed)
Thanks
Mark
Old Jul 9, 2009 | 02:00 PM
  #32
Bear.914's Avatar
I think I just got the same problem, car was making noises then 5 minutes later the car kept kicking out of gear and noticed an oil leak
Old Jul 10, 2009 | 09:52 PM
  #33
solipsism's Avatar
I think I may have the same problem too. Sorry if Im jumping on the bandwagon. I thought I was just being paranoid until about an hour ago.
Backing out of the driveway (w/o the music playing like usual), I heard a scraping from under my driving position or behind i think. It sounded as if metal was barely scraping something. It almost tinny sounded but not high pitch. It happened when I engaged the clutch into reverse gear with almost no throttle (car revs high off cold start).
I've never personally checed the oil in the diffs myself before and where I live is a pain for this kind of thing. I need to find a jack and check I guess.
I also notice some sort of drivetrain whine around 4th 5th both around 3000 rpm or so. Its very faint and not sure if its the tires or not. After I read about this problem I noticed it and thought I was being paranoid.
The history of the car is:
-25000km
-winter driven for 12,000 KM
-no drifting and very little tirespin (ASC left on in winter)
-no dropping the clutch or HARD launches
-decent amount of corning but nothign abusive. i drive my corrolla similarly
-S-AWC pump failed first week of winter. Didnt get a fix for it until spring (they couldnt get any pumps).
-Slight notchyness in shifting (got better as time went on but not fixed) mostly in lower rpms
-the drive train seems to clunk during cold start into reverse. Audible engagment sound from the outside of the car (didnt think it was unusual for this car---noticed it on other evo x) (i dont mean the sound of linkages/gearbox)
-pops out of gear every so often usually out of 4th or 2nd
-locks out of reverse regularly (like most standards i think)
-Service more then required (every time i make it to the city)
-last service was the 'D' type for extreme use (all fluids changed) a month ago
-NOT used as a race car or really badly enough to warrant the D-type service (i just idle a lot and a lot of cold starts and highway/city driving)
If I find a hoist or a buddy and a jack I plan on taking a looks at this after getting a shop manual or a howto if it seems doable. Other then that Ill try to get Mitsu to look at it. But I would rather be safe they sorry and send it off to get strengthened rather then spend the $5g's for a new one.
To the OP, If this is threadjacking Ill edit and start a new one.
Old Jul 13, 2009 | 09:09 AM
  #34
YShen15118's Avatar
I, too, am also experiencing some minor whining. It's present at around 2000-3000 rpm's for basically all my gears, although i'm not sure whether it's just a normal part of the transmission. I've never owned an AWD vehicle so i'm not particularly knowledgeable of how differently it should sound, compared to FWD.
Old Jul 13, 2009 | 10:05 AM
  #35
Mojito's Avatar
I'm totally fine with you guys chiming in. The more info we have on this problem and the reasons that are causing it the better.
Some whining is normal. But if you think it's not-like-it-was-before, then go and check it out.
Old Sep 18, 2009 | 01:23 PM
  #36
TrackDays's Avatar
Just noticed a very slight whine noise only in 4th gear between around 2k to 4k rpms. Should i be worried? GAH....
Old Sep 19, 2009 | 01:42 PM
  #37
boosted200ser's Avatar
Just a fyi buschur has a fix for this. I am not assosiated with them in anyway. But on a side note there are way more broken gsr trans than sst trans.
Old Sep 19, 2009 | 08:38 PM
  #38
TrackDays's Avatar
a fix would have been nice before i started hearing a whine.. who knows if its anything. I hope not. Whats the fix?
Old Sep 19, 2009 | 11:29 PM
  #39
felibon's Avatar
Buschur has a kit of pins for the center diff that are stronger than OEM.
https://www.evolutionm.net/forums/ev...solutions.html Good luck!!
Old Sep 20, 2009 | 01:07 AM
  #40
omni-star's Avatar
John Shepherd also has a fix to this.
Old Oct 19, 2009 | 07:05 PM
  #41
kijima's Avatar
And that would be because the SS-T is low impact when launched whereas the manual is not.
Mojito
45
Mar 8, 2009 12:19 PM
JohnBradley
53
Jun 28, 2008 12:55 PM
BlackTrack
Mar 1, 2008 02:38 AM
rACerS
24
May 25, 2007 06:50 PM
