Check Engine Light - Code?
Old Apr 4, 2009 | 04:34 AM
MDH-005's Avatar
I've just pulled up a Check Engine Light on a stock GSR.
When the light came up I was running on empty, so this might have something to do with it .....
The qustion I have is how do you find out the "trouble codes" ect .... PXXXX etc ....
Old Apr 4, 2009 | 04:58 AM
mrMTB's Avatar
Normally we would recommend stopping in on your local auto parts store and ask to borrow the OBD-II scanner. Don't know if you have that as an option in UAE. Fill it up and secure the gas cap tightly and don't worry about it for a couple days. If it was the gas cap not being tight, it'll go out on its own after a couple days. If not, then you'll need to secure a scanner.
Old Apr 4, 2009 | 05:25 AM
MDH-005's Avatar
Thanks for the advice. The amount of times I have seen people talking about codes I thought there might be some way of pulling the codes up on the display.
It seems like every man and his dog has a Scanner!
I've spoken to the garage and will take the car in tomorrow morning.... fingers crossed. I was only 5 min from home when it went ....... after it went the car was idling at 2000k and boost/power was restricted .... (not that I pushed it hard, I'm notbrain dead).
Thanks again
Old Apr 4, 2009 | 09:39 AM
jmorris1027's Avatar
limp mode. what are your mods?
Old Apr 4, 2009 | 09:49 AM
autobahntom's Avatar
If you know anyone who has a programmer for a late model car; that works as well. I have used one for a 2005 Mustang GT. Reads and clears codes just fine.
Old Apr 14, 2009 | 07:54 AM
journeymansteve's Avatar
Mine just threw the light last weekend after I just cleared the periodic maintenance reminder. Talk about jinx. I had just changed the oil, all good and no code looked like it could be thrown by a vibrating skid plate. Its in the dealership now getting demystified. The codes for the EVO I found here:
http://www.roadraceengineering.com/e...l-dtccodes.htm
Nothing looks straightforward and I haven't had time to install my TB mod, so all good for warranty coverage still.
Old Apr 14, 2009 | 04:41 PM
Just got the car back. Aside from being "talked to" about my K&N and dangers that oil presents, the problem was real code and was covered under warranty.
The "code" according to my service ticket, is P01320.
CAUSE: Inspected found code P01320. Electronic Throttle Valve Incorrect Position
13850190 TSB-Engine Module Reprogrammg
506 WM
...16807 Reprogrammed ECU, Cleanred codes and retested Operating as
...designed 13850190 .3 63-D-605
So I need a new OBDII kit to reset codes. Apparently that's all that was wrong -- this time.
Anyone else have this problem? Am I too hard on the pedal? LOL!
W_evo8
Jun 16, 2023 11:53 AM
jonjon123
15
Oct 10, 2008 07:50 PM
Evo818
Jul 4, 2007 05:34 PM
Thugline
10
Mar 3, 2006 07:18 AM
8urv8
Jul 21, 2005 08:27 PM
