clutch?
Old May 16, 2009 | 06:30 AM
  #31
Robevo RS's Avatar
i have an Exedy 3 pack single disk. I like it . But the true winner is the Exedy twin Only probblem , the category i run not allow more then a single disk clutch.
The Exedy single is grabs and holds perfect + not hard to drive at all.
If you have a money to invest on the twin, then get that. Much lighter on pedal then the single , specially vs the ACT but even with the Exedy single. Also much better for your drive train.
Old May 16, 2009 | 07:29 AM
  #32
smoke4's Avatar
We just had the me1hdss put in with the streetlite flywheel. Clutch feels like its actually there now, and I havent really noticed the flywheel at all. So far we are happy with it all, no real change in driveability. Just feels grabbier. Oh and when all was said and done it was about 1700.00. installed.
Old May 16, 2009 | 08:24 AM
  #33
trexxx8739's Avatar
how much did you pay for the me1hdss and what benifits does the flywheel have vs my just replacing the clutch?
Old May 16, 2009 | 08:44 AM
  #34
smoke4's Avatar
599 shipped, i just saw for a little less from thmotorsports. New flywheel can be lighter which helps engine rev a bit quicker and removes some rotational weight. From what I understand good for quick power shifting? Downside to that is loss of the momentum that a heavier one has, also possibly a bit tougher to shift normally. Also, depending on material the flywheel is made of, you can have a higher heat transfer coefficient which may help prevent a burnt clutch in the future. Downside to material change that ive heard is it can become more of a maintenance issue. The new material may actually wear down quicker than stock steel flywheel. Not sure if that applies to our car.
Nick at DTM did my install, he strongly recommended I get a new flywheel there before he took the car apart. He was saying almost every evox he did a clutch swap on had a flywheel that a simple resurfacing would not completely restore. So, while you are already spending 1400 or so to have a clutch put in...another 300 may be worth it.
Old May 16, 2009 | 09:37 AM
  #35
Western_man's Avatar
Originally Posted by flyguycfi
What did you end up doing to fix that?
Did you get the AMS band?
I ended up going back to a stock clutch and flywheel..
wm
febyzaoldyeck1
Nov 25, 2015 09:04 AM
MionieEvo
Dec 26, 2010 01:23 AM
Seifer780
Lancer Engine Tech
11
Dec 13, 2010 02:09 PM
xmaciek82x
Jun 29, 2010 09:44 AM
j14mp
10
Apr 26, 2009 12:43 PM
