Deatsch Werks 1000 cc injectors
Old Nov 8, 2010 | 11:24 AM
DeatschWerks's Avatar
I'm no tuner, but from what I have seen and heard feedback from a few of our tuners, you should probably scale your MAF first on the stock injectors before you install and tune larger injectors.
Old Nov 8, 2010 | 02:12 PM
VGergo's Avatar
okay, thank you but what about the 100% drop in fitment issue ? on every seller page are no mods need easy install but i have to use custom spacer and the side of the injectors going to the intake manifold is interesting too !
Old Nov 8, 2010 | 02:24 PM
The DW EVOX injectors are just a couple millimeters taller than the OEM injectors, but the fuel rail has enough play it hasn't been an issue.
We have sold thousands of EvoX injectors and also other applications that have similar fitment, and have yet to hear of someone needing to fabricate or locate spacers for their fuel rail.
I not saying this isn't the case in your situations, just letting you know this is the first I've heard of this issue.
Have you had a chance to pressurize the rail? If so, did all of the seals seat?
Old Nov 8, 2010 | 03:04 PM
VGergo's Avatar
we choosed the safer option, took some measurements and have custom spacer. Didnt take a risk for a chanche to have problem with the seals.
and what do you think about the 2 little things on the side of injector going into the intake manifold ? Why are they there ? I didnt see any space for it in the im .
here is the picture :
And thank you for your answer !
Old Nov 8, 2010 | 03:19 PM
Hey VG,
Feel free to PM me or email me a list of any questions you have. I try to make it onto EvoM daily, and am not always able to.
Chris@DeatschWerks.com
Old Nov 8, 2010 | 05:59 PM
delkat's Avatar
Mine are 1300s so the numbers will be different. Right now:
scaling is 713
Latency:
4.008
3.192
2.592
2.136
1.848
1.680
1.416
Old Nov 8, 2010 | 06:24 PM
JED_POLAND's Avatar
Hey VG,
Best if the questions and answers are done here as we all would benefit from it!
I am going to buy 850cc and I am confused right know due to that issue...
Old Nov 9, 2010 | 06:56 AM
I will post any pertinent Q/A done via PM or email, just would be nice to get all of the questions out so that I can answer or find answers promptly.
I only have so much time during the week that I am able to get on the forums.
I will answer the tab question, though.
The tabs are there as a design of the Denso injector used for the EvoX application. It has no bearing on the function of the injector. They are not meant as a stop or to go into slots on the intake manifold. The lower oring is what creates the seal on the IM, as long as it is properly lubed and installed there should be no problems.
SKY888
May 8, 2018 01:44 PM
MDamman003
Dec 14, 2015 12:31 AM
Madrican
Feb 17, 2011 10:05 AM
David Buschur
31
Nov 2, 2009 05:55 AM
Chris@AMS
54
Mar 11, 2009 03:22 PM
