EVO X 5 Speed failures and solutions
So the shafts get stuck inside the gears probably from overheating, expanding fracturing or whatever. In any case, it implies heavy load on diff.
If you put superstrong pins to hold shafts from rotating with the gears, then what? Either shafts will go, or the gears will destroy.
The solution should be to prevent the shafts from getting stuck inside the gears. The pins are just a fuse there.
David, can you comment on how exactly you are dealing with this problem?
Simple answer to not breaking the transmission is to change the transmission fluids.
I abused my evo on track, gravel till today which is already 10000 KM and no problem for transmission or clutch.
Good luck guys and please dont babysite your car!
My goals:
1) finish the 1/4 mile in 4th gear with some room to spare.
2) better gas milage/less wear and tear @ 80mph.
3) I also drive it on small road course which is 95% second gear, and I think it might put me in a better part of the powerband for the faster stretches and save a shift or two into 3rd.
4) I could also run a smaller dia/lighter tire without worrying about spinning the motor even faster on the hwy.
My current trans is still holding up at about 380whp/340ft-lbs..... for now.....
That's what I'm wondering. Just how much power were people putting out with their X's to break the tranny and/or differential pins? I'd like to think that it would be able to hold up to definitely stock power, and hopefully with some mods. ~350 hp/tq at wheels.
At what point should you upgrade your trans and differential? I know it's cheaper if you do it before it breaks.
I don't think it's the matter of how much power you have in the car, but certain conditions where diff is overheating causing the shafts to get stuck. You can break the pins with a stock car (which already happened not once).
You could send your trans in and have it worked on to prevent the problem. It doesn't seem anything that you mentioned will prevent the poor engineering design...
Probably it would be ok with around 600 crank HP or mid/high 10's at 128 mph where 5th would feel like it's pulling you through ~15 mph of speed versus under 5 mph like it is now at 500 crank HP. So maybe the answer is just mo power: cams, intake manifold and race gas to get better use of shifting to 5th!
