clutch questions
Old Sep 26, 2009 | 09:35 AM
robh's Avatar
clutch questions
So i launched the x last night now my clutch is acting up
i have an exedy twin disc and now when i drive the car my clutch engages right off the floor and it is hard to put in gear i think it is prob the master or slave cyl
what do you guys think?
and no it is not slipping it just has an early engagement
Old Sep 27, 2009 | 09:04 AM
monkey_187's Avatar
You should have the the shop that installed it check it out, unless you did the install.
Old Sep 27, 2009 | 09:42 AM
robh's Avatar
i did the install and i have 10k miles on it
now if it was a bad clutch it should not engage tell the very top of the pedal
but for some reason it is engaging right off the floor which would tell me it has to be the master or slave cyl
just wanted other thoughts
Old Sep 27, 2009 | 10:34 AM
EvoX2NR's Avatar
maybe there was an air bubble in the line.... try bleeding it
Old Sep 27, 2009 | 11:10 AM
autobahntom's Avatar
There is a problem that shows up under very hard shifting. The release bearing retainer comes apart-when pushing the clutch pedal-the linkage in the bellhousing can sometimes travel too far. There is a fix for it, DG Motors has the parts. Have to pull the trans to fix though.
Tom
Old Sep 28, 2009 | 08:55 AM
SPEC-01's Avatar
The most likely cause for a low pedal in an EvoX is air in the system. I assume that you bled the hydraulics but I suggest the use of a mighty-vac to do this as it uses vacuum to pull the air out. You should bleed from the slave as well as from the reservoir. Give this a shot and let us know if there is improvement.
Old Sep 28, 2009 | 10:56 AM
jk68x3's Avatar
Have u done any fix to the clutch master cylinder? If not I would start there
Old Sep 28, 2009 | 11:15 AM
Guru's Avatar
Mine has been doing it every once in a while. Doesn't seem like completely disengaging. I suspect air in line butu sine I'm swapping out to EVO 9 MC tomorrow haven't bothered to bleed it.
JDavenport
33
Aug 22, 2016 04:44 PM
The_Police
Apr 6, 2016 07:05 PM
Go_Lancer_Go
Jan 19, 2010 09:46 PM
wicked white14
May 6, 2009 03:51 AM
Jacoby
11
Jan 5, 2007 04:26 PM
