First Mil.Spec bolt-on HFC installed
Old May 19, 2010 | 12:00 AM
  #31
DaFastOne's Avatar
Originally Posted by St1g
not to sounds like i'm picking on you, but come on, you really think CARB is about saving the environment? think about it--why would any organization need to certify any aftermarket component, supposedly for environmental reasons?: if the bottom line is how much pollutant is created, why are not the results of a smog check valid and complete enough by themselves? and if you say that smog checks as they are conducted today are useless, then they can easily be bettered, or they might as well be discontinued.
it's all a joke man. the only sensible reason CARB exists is to make money for the government, and for the political gains of its supporters. think about it... who pays for certification? who gains when a car is caught with illegal components? who looks better when stricter rules are made?
as for your argument about a high flow cat not being able to pass, do you mean specifically on an evo, or on all cars in general? because i have 3 cars, all of which have high flow cats, and all that have been tested have passed. sounds to me like you mean just on an evo though... but sorry if misunderstand, as it's hard to follow your logic.
All good, but i have been to Sacramento and listened to a hearing where C.A.R.B. was discussing evironmental issues, and let me just say this, automobile not even their biggest issue, they talk about agricultural machines, companies waste products even aerosol products, its actually no joke. they are trying to solve problems where the quality of air is terrible.
The new smog laws are trying to solve some problems which w/ people are creating. People are trying to holding on to their POS cars that are causing pollution, people with old cars change their cats like every year b/c the owner of the cars will not fix the real problem and will put on a new cat when then need to go for smog. A cat should not go bad unless the person doesnt maintain their car properly. The new laws require people to fix the origin of the problem of the car instead of having a new cat just bandage the car's really problem. The system is not perfect and people try and short cut or find loop holes.
As for your high flow cat, im mostly talking about the metal substraight cats and not the ceramic brick cats. The EPA method of classification of cats is a old method of classification. When a cat says its rated for 5.9L, 6,000lbs rating this is a method of rating back in the 70-80. which cars were only carburated. New fuel injected cars flow alot more exhaust and air compared to the old cars. (man i am really straying away) But anyhow, how do you really know how much Platinum, ore palladium or even rhodium your cat uses. those metal cats are usually crap, i have used many different ones: Maremont which is now cherry bomb metal cats, magnaflow metal substraight cats even the Cobb high flow metal cat is crap.
Most stock cats are in the 600cell counts, and are heavily loaded w/ precious metals, do you think your aftermarket cat can even compare to reduction or oxidation of your stock cat. There is a reason why people are stealing cats of OEM and not aftermarket.
I must appoligize my english and my thoughts since i have a tendency to ramble on.
Old May 19, 2010 | 12:09 AM
  #32
St1g's Avatar
interesting... thanks for explaining! and i didn't know carb covered so many other things than cars. ....i still don't understand why carb certification for car parts is needed at all though. if a single car's overall pollution production meets measureable guidelines, why does it matter how each individual part is designed? i guess that's my main point--why care so much about an individual part, especially when you consider its performance is always affected by the system where it is integrated?
Old May 19, 2010 | 12:21 AM
  #33
Erik@MIL.SPEC's Avatar
We can now offer cats for people **** about CARB certification...but they're 300 cell units (I think) and not 100.
Old Jul 10, 2010 | 10:24 AM
  #34
seventhfactor's Avatar
OP how did you get your wb02 sensor to reach? My car is stuck in the garage. I just can't figure out how to get the lc1 wb sensor to reach that side. My test pipe had the sensor bug on the passenger side.
any ideas?
Old Jul 10, 2010 | 10:49 AM
  #35
any ideas?
There should be enough length in the 02 sensor wires. We suggest to zip-tie the wire to the driveshaft support bracket when you run the wire to the other side.
Old Jul 10, 2010 | 11:06 AM
  #36
That's a good idea. It looks like my lc1 cable is just crazy short. I'll be ordering a longer one.
I'm very impressed by the weight of this hfc. It weighs about as much as my test pipe. Good job Erik!
Erik@MIL.SPEC
EvoX 'For Sale' External Engine / Power
25
Sep 15, 2015 11:07 PM
razorlab
66
Dec 14, 2013 03:58 PM
HAHAV8
17
Nov 21, 2011 08:49 PM
Erik@MIL.SPEC
Oct 18, 2010 10:15 AM
orthojoe
Evo X Dyno Results
42
May 2, 2010 08:35 PM
