Analyzing a critical engine flaw in the 4b11 by TTP
Old Mar 26, 2010 | 11:38 PM
  #211
onboost's Avatar
Originally Posted by spdracerut
With inlines, there's definitely the potential for starving the last cylinder of air due to the intake manifold design, namely the air coming in from one end of the manifold and not 'making it' to the far end. Maybe a combination of exhaust manifold design too.
If you look at the V10 and V12 Porsche and Ferrari engines, the air enters the intake manifolds in the middle. Pretty sure Lamborghini too.
Wouldn't that make the last cylinders run rich instead of lean? From my understanding rich runs colder than lean. So those cylinders would suffer from too much air instead of not enough
Old Mar 27, 2010 | 08:12 AM
  #212
whtrice's Avatar
Veteran: Air Force
Normally.... rich does cool things. So in speculating that it could possibly be a lean issue at one cylinder. Is there a way for the stock ECU to provide just one injector with a specific pulse width to tailor it's AFR? I know I have seen race setups ( assume using a standalone ) appear to have EGT sensors on every exhaust port for that purpose.
Old Mar 27, 2010 | 01:24 PM
  #213
EvoG8r's Avatar
Originally Posted by TTP Engineering
Haven't seen any E85 failures which I believe are attributed to the 30-50*C lower EGT's which I am sure put a bit of a damper as great a piston expansion than on pumpgas.
My simplistic reasoning makes me think that if heat is an issue, then meth injection and upgraded intercoolers would be good too?
Old Mar 27, 2010 | 02:31 PM
  #214
Golden's Avatar
Yes, there are Cylinder Fuel Trims.
Old Mar 28, 2010 | 05:00 AM
  #215
evo400's Avatar
Registered User
Hi guys
Are your aware what piston type you are running in the failed motors ?
Have a look @ www.ralliart.com , download the evo x grpn papers .You will see there was a number of early changes to piston type . Page number 74 of 87
Hope this helps
David
Old Mar 28, 2010 | 11:30 AM
  #216
onboost's Avatar
Originally Posted by evo400
Hi guys
Hope this helps
David
its the bottom one
Old Mar 30, 2010 | 12:17 AM
  #217
HybridKOOP's Avatar
Originally Posted by onboost
its the bottom one
Where is this from the Ralliart main page? I'm not seeing any Green Papers links...
Old Mar 30, 2010 | 07:55 AM
  #218
Spy007's Avatar
Originally Posted by ct63084
Lol nothing on the people here, but i found it funny that this thread is right on top of this.
https://www.evolutionm.net/forums/ev...ml#post8131489
I think you jinxed it.... way to go! 2 days later and BOOM...
https://www.evolutionm.net/forums/8141002-post34.html
Old Mar 30, 2010 | 12:14 PM
  #219
ct63084's Avatar
lol that motor is still impressive nonetheless.
Old Mar 30, 2010 | 07:26 PM
  #220
love9sick's Avatar
Originally Posted by hollywood_X
Everyone I've seen so far that has blown a motor has had the original fuel relay in or had just swapped to the new one and boom.
What do you mean new one? The green and blue ones are blowing also? Who has done this on a new green+ relay?
Old Mar 30, 2010 | 08:53 PM
  #221
Golden's Avatar
No, he means that the black one did all the damage and they just swap to a new one and the engine goes boom. Not the new relay's fault.
Old Apr 5, 2010 | 09:58 PM
  #222
DRAG's Avatar
Hi guys
Hope this helps
David
Where does it say anything about a piston replacement? I read through and see nothing.
Old Apr 6, 2010 | 07:01 AM
  #223
MR Turco's Avatar
These failures look very similar to the B15 Sentra SR20 failures when adding a turbo. The root cause of those failures was the top ring landing was too high and after too many heat cycles would crack looking just like this.
According to what i have read on the SR20 failures the higher ring landings promote better emissions. I haven't compared the 4g63 pistons to the 4b11, and i could be totally off base, just looking at the failures compared to another similar failure on a different motor platform. I would also be hard pressed to think that a company with 20+ years in turbo experience would get something like ring gaps incorrect.
Old Apr 8, 2010 | 08:33 AM
  #224
APM Racing's Avatar
The EvoX top ring is 5.5 mm down and the 4G63 topring is 5mm down . As for the ring end gap on a 4g63 is usually around .010-.012 from the factory for the top ring. The majority of ring end gaps are from aftermarket piston makers who use forged pistons compared to the factory cast/hyper pistons which do no expand as much. I will say though .007 does seem kind of small.
Old Apr 21, 2010 | 01:19 PM
  #225
kyoo's Avatar
did anyone ever get to the bottom of this?
