Differential/ tranny blowing
Old Apr 13, 2010 | 08:27 PM
EVOXTIMES's Avatar
Originally Posted by fast_bloke
I replaced my Center Diff pins with the Buschur Racing parts as I was doing the clutch anyway (stock clutch is awful) and heard about these issues. That was at about 9K miles.
I attach pictures of the pins that were removed.
As you can see they are showing signs of fretting on the small pins that hold the large pins into the Center Diff. If these smaller pins shear, the larger pins fly out under the centrifugal force of the clutch and machine their way through the outer gearbox casing (for those that don't know the center diff is in the gearbox, and the front diff is in the transfer case).
I thrash my car every day (if you got it, use it, including the odd hand brake turns, clutch drops and of course sideways action under power with ASC off wherever possible) and now have 15K miles with 300AWHP ( I had 450 for about 500 miles but hated the lag ).
No signs of issues so far. Fingers crossed.
can someone send me a link to the upgraded pins on buschurs site. I cant find it anywhere. im having my clutch put in tomorrow...and like to order these.
Old Apr 13, 2010 | 10:28 PM
Bear.914's Avatar
They are only available by phone order from what I hear and I believe the guys name is dan who deals with the part...idk why but thats what everyone is saying
Old Apr 13, 2010 | 10:59 PM
Mojito's Avatar
Originally Posted by pyrofire127
iIdk of any for sure way to tell if your pins have broken, only thing i could think of was my tranny fluid came out like a silver metal slush. if anyone knows of a sure way id love to know it for future problems
After my second diff went, I installed the GBT sensor just for that puropose. If I ever notice that my GBT gets too high too quickly, this will be an indication that the GB is running dry and overheating.
BTW, the hole in the case is caused by a bump inside the case. When the pins break and the shafts come out of the diff, the shafts rub against the case and puch a hole where the bump is. Initially I thought the hole was due to impact by the shaft coming out until I saw the inside of the casing. So, I guess, if you flatten the surface of the case in that place you may avoid oil leak and destruction of the rest of the transmission. Just a thought.
Old Sep 14, 2010 | 06:34 PM
GTR2009's Avatar
I have a similar problem, not sure yet if the diff pins are the problem, I have stopped the car before the transmission failure...
Please read my post https://www.evolutionm.net/forums/ev...nsimssion.html
David Buschur
197
Jan 11, 2015 01:44 PM
d3r3k
Jul 19, 2012 04:51 PM
JebusMKIV
96
Nov 19, 2011 05:12 AM
Last4G63
33
Dec 7, 2010 02:32 PM
insanechief
29
Feb 12, 2009 10:44 PM
