EVO X Transmission failures. Hmm.. I'd appreciate your input.
^ Obviously has never driven a X and STi back to back on windy roads or a track... I would definitely not call it a monster compared to the STi. And granted, throwing mods at a car to make it better completely ruins the argument. But do an alignment or springs or sway bar (anything to fix the understeer on the STi) and you'll have a car that is a dream to drive.
Sure S-AWC is a great set up, sure it'll make any crappy driver better. But does it make a GOOD driver better than the same driver in an STi? No, not even close. I felt more comfortable pushing the two Xs I extensively test drove. But I didn't feel it was any more capable than the STi.
I do plan on getting myself into one of the newer spec-c equivalent (special edition in US) to see how they compare. Subaru seems to have upped the ante with this release.
Then again, this is coming from someone who used to drive a race prepped S2000, which could snap around on you any second, and easily out cornered my Evo. Sure it was scary to push anywhere near the speeds the Evo could do, but it could do it, and do it better. Thankfully the STi just understeers like a pig in stock form when you push it too hard. Drive it right with the DCCD set to Auto[-], S# mode, and the TC off and it drives just fine.
Personally, both cars are completely equal, just as they have always been. They both have their ups and downs (Evo can handle more power in stock form and is cheaper to mod/maintain). In the end. I've had bad luck with Mitsu and have always wanted a fast hatchback. Plus the X's turbolag was still too much for me. The choice was obvious.
In the end, what you should do is drive both, decide which one you like better based on your own factors. They are both very very amazing cars, and other than the two of them, there's nothing else quite like em.
truth. anyone who talks a lot about the differences between Xs, STIs, and even the older evos is honestly exaggerating a lot - there are noticeable differences, but overall performance is all within < 1 second of each other.
Only threads I've seen about it are
https://www.evolutionm.net/forums/ev...solutions.html
and https://www.evolutionm.net/forums/ev...nder-clip.html
Not directly related to just the transmission and gears, but closely related
I think the Evo's greatest strength is its ability to make me, a nerd, who enjoys anime and touching myself to furry ****, feel like a ****ing ninja on a curvy road. My own 2006 STI, and 2002 WRX, never give me the feeling of confidence at the limit. Now, granted, this is because I am a horrible, horrible, horrible drivers, and the AWC is my own personal *****, but I'd bet good money that more people are similar skill to me as opposed, to, say, anything approaching "good".
very well put.
In terms of the STI or Evo thing, I'm sure if you work at the Subaru HQ you know the STI stock suspension is set up to understeer from the factory - And a simple suspension swap completely changes the handling characteristic of the car - the stock suspension is somewhat a limiter of the car's handling.
I wrote somewhere else, after driving the cars, I actually prefer the drivetrain of the STI overall when set up properly
Not just the casual daily driver - but that's a separate issue.
Totally agree. But I was just comparing them in the stock form. If mods are brought into the mix, its a whole different ball game.
The only complaint I have with the evo x GSR transmission is it's notchiness but once its warmed up it's good to go. As far as the MR go you can get clutch packs and you'll be good to go I think SSP has a 11 sec MR. The only thing that i would say you really have to watch out for is the damn fuel pump relay a couple of guys had their engine blow up because of it, good thing is it's only ten dollars to replace it.
2008 X GSR 14k mile approaching , hard lunches , exedy triple disc clutch other wise bone stock drive train. no issue. Thats all i have to say ...
here is one turn from last weekend, so you know its not a DD...
http://www.youtube.com/watch?v=b2xTXQQwfQI
Rob
Rob
Best way to answer this is to drive both your self. I use to own a 05 STI and loved it to death so when it came time for a new ride I tested a 08 STi. I then tested a 08 Evo right after and have to say the evo's awd is what sold me. There's a nice tight little round about near the dealerships so I got to take both cars on the same route. I couldn't believe how well the evo stuck to the ground vs the rear end happy sti.
The new sti is going back to the sedan from the wagon so if looks is big I would wait till those hit the show room floor and see one in person.
The MT itself is ok, but the center diff is the weak part. It often fails and causes oil leak. That in turn may destroy the tranny. It happened to many people (myself included).
The stock clutch MC is also a ****ty part and breaks with a stronger clutch.
crcain
26
Aug 23, 2016 02:48 PM
Aashenfox
Nov 29, 2014 10:34 AM
Tuor
Mitsubishi TC-SST Discussion
17
Nov 21, 2011 05:09 PM
beef, drivetrain, engine, evo, gearbox, gsr, horsepower, limit, limitations, mr, power, problems, stock, tranny, transmission
