AEM Intake and FP Red?
Old Aug 24, 2010 | 06:10 PM
1FastT2's Avatar
I'm currently running an AEM Intake and am preparing to and an FP Red in the next few weeks. Will I be able to adapt the AEM intake to the FP Red 3" intake? I like the AEM intake and would like to use it with this turbo if possible. This car is my DD and I perfer not using an open element filter. Any ideas?
Old Aug 24, 2010 | 06:34 PM
Golden's Avatar
I ran into the same issue.
I purchased the Cobb 3" FP Inlet Tube and made a custom mount for my AEM MAF Housing. Then I slapped a cone filter on the end.
You can use the Cobb Inlet with the AEM just fine.
Old Aug 25, 2010 | 03:20 AM
1FastT2's Avatar
Excellent, thanks for the reply, I'll have to give that a try.
Old Aug 25, 2010 | 05:46 AM
Messidona's Avatar
Golden.. dont you run into issues without the fan shroud?
Old Aug 25, 2010 | 07:58 AM
Golden's Avatar
Nope. None at all. I've heard that it's because my filter is so far away from the fans.
Old Aug 25, 2010 | 08:03 AM
D__'s Avatar
D__
Looks good Golden. Can we just buy that AEM maf housing seperate?
Old Aug 25, 2010 | 08:37 AM
Messidona's Avatar
I had the same issue - haven't installed. I just sold the AEM and got a full 3 inch intake like ETS or AMS and get one of the couplers swapped to a 3 inch coupler. The alternative was to do what golden did and was to buy a the new COBB 3 inch inlet.
Old Aug 25, 2010 | 12:31 PM
Golden's Avatar
I don't think so.
Old Jan 12, 2011 | 08:11 AM
twinturbogreg's Avatar
So the Cobb FP inlet fit over the AEM MAF housing??
Old Jan 15, 2011 | 09:33 AM
Evolessfornow's Avatar
I want to know as well.
Old Jan 15, 2011 | 12:36 PM
saytheb's Avatar
The AEM turbo inlet pipe is tapered down to the stock turbo inlet size. At the top, it's 3". I took a 3" CF pipe from another exhaust, cut the AEM turbo inlet pipe and this other exhaust, then fit them both together. It was a very ghetto fix, but it worked..
I'd recommend just doing either as Golden mentioned or buying a true 3" intake.
Admin2304
Mar 28, 2017 09:17 AM
Dross99_si
Mar 4, 2016 08:27 PM
KFC-AWD
Oct 4, 2015 06:51 PM
RunThat
32
Aug 5, 2015 04:16 AM
marinejensen
16
May 18, 2010 02:36 PM
