Not sure why fuel pump isn't priming anymore
Old Sep 5, 2010 | 01:31 PM
inhocaviles's Avatar
Question Not sure why fuel pump isn't priming anymore
I've been having several fuel pump issues recently ever since I switched from the stock unit to a Blaqops single pump. The pump no longer primes when starting the car (I don't hear it like I used to). The car turns over for about 8-10 seconds before it has enough fuel to start.
I've checked the relay and fuses and they all seem fine.
Anyone know what's going on?
Old Sep 13, 2010 | 05:35 AM
Getting ready to install a double pump, anyone have any thoughts on why the fuel pump isn't priming?
Old Sep 19, 2010 | 03:31 PM
Figured out what happened with my fuel system.
I have the Blaqops single pump kit, and it turns out that my problem is with the Gates hose that comes with the kit...the hose literally split wide open!!! I'm real lucky I didn't blow my engine!
Not sure what the deal is with this hose. I'm running 93 gas and the Gates hose split and is showing visible signs of wear. I'm going to start my search tonight for a more appropriate hose for inside the tank.
Old Sep 19, 2010 | 08:33 PM
D__'s Avatar
D__
Pics?
Old Sep 22, 2010 | 02:42 PM
mlomker's Avatar
Wow. BlaqOPs uses the most expensive type of hose, 30R10, which is rated for E85 in-tank. If you're sure that you'll always run pump then you could use the less expensive 30R9. 5/16" should be the size.
Tyrel Bursaw
Jul 23, 2018 02:26 AM
Sp1kE
Aug 9, 2016 07:55 AM
sworddemon
Mar 16, 2016 08:35 PM
bostonhatcher
Mar 29, 2013 01:06 AM
EvoFredo
Apr 24, 2012 09:54 PM
