stage 1 or stage 2 clutch
Old Oct 22, 2010 | 12:39 PM
freshpl's Avatar
after doing some reviews i will be going with the exedy clutch kit
Q- which stage 1 or 2 daily driver but i drive and launch the car hard
330whp no more mods will be done.
whats the dif between the two stages i searched and found that the stage 2 is thinner?
if someone could help out for some +1 karma
Old Oct 22, 2010 | 05:44 PM
glomb23's Avatar
I'm honestly not too sure which direction you should go regarding the clutch, but hear that exedy's break the CMC relatively easily so maybe while you're changing out the clutch think about upgrading the CMC too. I know when I need a new clutch that's what I'll be doing.
Old Oct 23, 2010 | 12:15 PM
freshpl's Avatar
thanks for the reply will i have problems if i don't replace the cmc along with the clutch?
Old Oct 23, 2010 | 03:12 PM
glomb23's Avatar
Well I'd say it's more a precautionary measure than saying you'll definitely have problems. It's just been somewhat common that people with Exedy clutches break the CMC. I'd replace it just to be on the safe side just so you don't have to deal with it IF it does break.
Old Nov 18, 2010 | 10:43 AM
freshpl's Avatar
ok so i had the stage 2 clutch installed..
now is this normal..if im at a stop light and start to accelerate slow the car just starts shaking like a tractor..but if i launch it no problems..
and finally after the install the service engine light turned on the one with 4 wheels on the display and i can't change from tarmac to snow etc.. so went to dealership they reset the ecu for the wheels or something they told me. everything was fine now it pops up again.
any suggestions i don't want my rear dif blowing out..
Old Nov 18, 2010 | 11:17 AM
zabes's Avatar
the shaking is because your near stall speed on the engine. you should give it a little more gas at start. i have the stage two as well and love it so far. i swapped my cmc with the ssp unit just to avoid having any potential problems later on. also, the differences between the exedy clutches are that the HD are as thick as the stocker and the sd ones are half thickness. at least thats what i was told.
Old Dec 13, 2010 | 01:30 AM
MDH-005's Avatar
This is normal ..... I've just has a ceramic twin installed and it does the same thing ..... you have to break it in for about 700-800km .... low revs, no launching, no hard changes.... also dont slip the clutch during the shudder that wont help at all....
Old Dec 14, 2010 | 11:41 AM
Jake26's Avatar
Question, i wanna do the exact same clutch stage 2, where did you purchase yours, and how much, also what is CMC? not familiar with that akronym?
Old Dec 15, 2010 | 10:33 AM
slim64's Avatar
cmc=Clutch Master Cylinder
http://www.maperformance.com/magnus-...c-upgrade.html
Old Dec 16, 2010 | 09:52 AM
Synaptic3e's Avatar
I bought the AMS Master Cylinder reinforcement ring when I just installed my ACT clutch kit. PM me if you want one and I can get it for you.
haxr303
Mitsubishi TC-SST Discussion
Oct 30, 2023 07:26 PM
real fast
16
Nov 21, 2016 09:49 AM
Moore Auto
EvoX 'For Sale' Engine Internals and Drivetrain
Feb 10, 2015 08:37 AM
johnnnyjeans
Cobb AccessPORT
Apr 29, 2012 09:00 AM
select21
13
Jun 16, 2011 06:56 AM
