P0234 Turbocharger Wastegate System Malfunction.
i was driving home the other day it was about 30degrees and the car was a stuttering so i shifted to 2nd and floored it and the car jerked violently and the cel P0234 Turbocharger Wastegate System Malfunction. only has a C-PE hi-flow cat and cat-back exhaust. has anybody had this happen and should i b worried, amd why did it come up
I had this problem. I was driving at -5 degrees Celsius (23F) and I got this code. Basically the car would accelerate hard... then there was a cut in power... and then the car would keep driving. Then the CEL would pop up.
Basically the tune that I had was fine during the spring/summer/fall... but when the temperatures went really low in December... the car was boosting too much. So I had to switch maps to one that didn't boost as much. Now my car is running fine. When spring comes along... I will switch back to the normal map.
hey guys, i have the same problem as well, and then i got the dealership to check it, it is the
turbo wastegate seized, have to replace the whole turbo. funny? or can i do something to fix the problem.
91 oct stage 1 map, cobb uicp & licp, k&N fillter, cobb cat back exhuast , ams hfc,
and the dealership said the turbo and wastegate is in one piece, so, i think it is the internal wastegate, i did a lot o research, i kindda have the feeling that the dealership is wrong, lol.. i think it could be a bad tune, or my relays are bad,
i am going to order the relay today. what do you guys think, i love my evo
SudzRA
Jan 9, 2012 11:31 AM
c12, cat, dtc, evo, evolution, malfunction, mitsubishi, mr, p0234, problem, psi, system, turbo, turbocharger, wastegate
