I recently had a private transmission shop put a new exedy stage 1 organic clutch and fidanza aluminum flywheel in my car and a couple of things are starting to worry me...
no pun intended, but for starters the evo is making a short screech right before it turns over when starting and after driving for a couple of minutes all 3 ACD lights turn on. i did a little research and saw that the ACD needs to be reset after a clutch change so im hoping that all i need to do is bring it to the dealer for that, but im wondering if there is something else i might need to be aware of.
about the starter noise my mechanic told me that the OEM flywheel was slant cut where it connects with the gears and the new flywheel is straight cut and he was hoping the noise would go away once it is broken in...
please be completely honest with me, i just want to make sure everything is done right so i have no future problems
thank you much...if anyone is in the milwaukee area let me know
james
james
do you have an VIII or X? you are posting in the evo x section assuming you have a X?
