No reverse?
Old Nov 21, 2011 | 03:47 PM
salvatruco2004's Avatar
No reverse?
So i got a act 6 puck and streetlite flywheel install, drove the car 3000 miles and no problems. Then reverse decided to dissapear, i have to push my reverse couple of times then it will go in. Its pretty weird, anyone have this problem? All the gears are fine. By the way this is for my evo x.
Old Nov 21, 2011 | 03:51 PM
T-Pain's Avatar
I think that's normal.
I'm not able to get into reverse every now and then as well
Old Nov 21, 2011 | 04:02 PM
Yeah i read some threads, but mine i basically have to push my reverse couple of times then it goes in. Never had any problems with reverse before.
Old Nov 21, 2011 | 04:03 PM
Even when the car is off i have to do the same stuff.
Old Nov 21, 2011 | 04:26 PM
Vivid Racing's Avatar
I've driven a ton of cars that did this. Try creeping forward a few inches in 1st, then going to reverse.
Old Nov 22, 2011 | 06:13 AM
Thanks, i just hate the fact that is not easy going into reverse. Any more info?
Old Nov 22, 2011 | 06:23 AM
deanob's Avatar
Try 4th then reverse gear. It's a usual practice I learnt with my DSM now its just second nature.
Old Nov 22, 2011 | 12:16 PM
01CBR929's Avatar
Mine has trouble going into reverse sometimes... first gear raaaarely. Exedy triple disk here.
Old Nov 22, 2011 | 04:45 PM
Kracka's Avatar
Sounds like the clutch might be dragging slightly. The reverse lockout is somewhat normal on the X since it has no actual dedicated reverse gear, but if it only started since the clutch job then I think it's fairly obvious what the problem is.
Old Nov 22, 2011 | 05:41 PM
Spazpilot's Avatar
slowly lift the pedal as your putting in reverse or like it was said up above put it in any gear then back to reverse. Seems to be somewhat normal on the X's. Mine does it sometimes and the car only has 500 miles on it.
Old Nov 22, 2011 | 06:16 PM
problem is that the car wont go into reverse even if its off, i try go upload a video tomorow.
Victor Hong
Jul 13, 2016 08:19 AM
evo82005!
Oct 13, 2015 07:21 AM
pensport
Sep 7, 2009 09:53 AM
stdreamy
Feb 13, 2007 07:52 AM
STOCK_EVOLUTION
18
Dec 26, 2006 02:46 PM
