Exhaust Hangers
Old Apr 6, 2012 | 05:43 AM
fcruz3r's Avatar
Exhaust Hangers
need help guys, just swapped my exhaust from a 2.5inch to a 3 inch t1r system. with the rear muffler, if I use all 3 holes on the stock left and right hanger the muffler sits too high and the bpipe touches the rear subframe.
I can hook it up using just 2 holes on the rubber hanger on each side (using only the long side of the triangle rubber hanger) ...this is how the t1r website recommends the exhaust install. but having it this way causes too much side to side sway on the exhaust. its ok for normal driving but think theres too much movement for the track.
hope some of you peeps running into similar problems can chime in on how to rectify the problem...or if there's aftermarket hangers that are longer than the stock ones.
Old Apr 8, 2012 | 07:44 AM
waltezee's Avatar
Are you running a test pipe or aftermarket dp?
Old Apr 10, 2012 | 04:54 AM
fcruz3r's Avatar
its a cbe
Old Apr 19, 2012 | 09:58 PM
rcantu's Avatar
it's the sparrow,right? i just installed mine and used both hangers the same as oem.
be sure the b pipe resonator is towards the rear and the emblem is facing upward not down. i read going the wrong way it makes problems.
Old Apr 20, 2012 | 10:43 AM
linjy2's Avatar
My install back in 2008 https://www.evolutionm.net/forums/ev...pics-lots.html
I also did my hangers the same as OEM if I remember correctly. But the newer models I heard of them asking people to flip the rubber hangers or something.
rydogg008
Evo X How Tos / Installations
11
Jan 31, 2015 06:19 PM
emperor496
Apr 15, 2014 09:50 AM
yorT
Jul 14, 2012 11:02 AM
PaganImmolator
12
Aug 18, 2011 05:24 PM
2004BlkEvo8
Aug 18, 2004 10:49 PM
