Got a cel light after cat install
Car was tuned, about 100 miles later I get a cel.
He was able to disable the rear o2 sensor, I think is bad.,
It was backed out from the original oem the thread was stripped & tip looked a little dirty, car had less than 5k it's a 12 mr.
What do people do that run test pipes, that need emissions done.?
Do you guys just toss the stock cat on for that, or can it be fixed via tuning. ?
I'm running HFC aftermarket
Thanks for any help would be greatly appreciated.
Tuner can disable the P0141 code from your ECU, but you will have issues when going for emissions testing as the sensor will not be in the ready position. My suggestion is to purchase a 90 degree CEL FIX. This way you'll be able to keep the sensor in ready postion w/o throwing a code.
USP45
20
Jul 21, 2009 04:31 PM
USP45
84
May 2, 2005 07:54 AM
