Straight test-pipe rattle
Old Nov 20, 2013 | 01:29 PM
zanelefko's Avatar
Hey evomers,
I have a straight test pipe which rattles and I cant seem to figure out why? It doesnt touch anything such as heat shields or any bolts but still has this pesky rattle. Before I spend $100 on a rexspeed pipe WITH the bend, is there anything I can do?
I know its a very very vague plea for help but hey I figured it wouldnt hurt.
Old Nov 21, 2013 | 01:05 AM
Papogremlin's Avatar
What is a test pipe what does that mean?
I know I am stupid no need to point that out
Old Nov 21, 2013 | 01:56 AM
tbaird58's Avatar
test pipe replaces the catalytic converter and opens the exhaust up, as for the test pipe have you jacked the car up and started it? it might not be your test pipe, my downpipe rattles against my lower support rod
Old Nov 21, 2013 | 06:19 AM
Kracka's Avatar
I bet it is very close to the driveshaft carrier support and the engine vibrations are causing enough movement for your pipe to hit. I suggest only using testpipes or HFC's with a bend in them just like the factory catalytic converter. Shops using a straight pipe with angled flanges are taking a shortcut to reduce their costs of production.
Old Nov 21, 2013 | 08:45 AM
zanelefko's Avatar
I agree KRacka, but I got it for free so I didnt complain =) Ill jack it up tonight and check to see..
Old Nov 21, 2013 | 06:01 PM
Scootypuff86's Avatar
I have the Depo Racing test pipe, which is straight in design, it will rattle if put on backwards so you may try flipping the test pipe around.
Old Nov 22, 2013 | 06:07 AM
zanelefko's Avatar
thanks! if it isnt hitting anything Ill just unbolt it and flip it...are the flanges angled different? I honestly dont remember if the flanges are different on mine as its been 13k miles since I put the thing on
Old Nov 22, 2013 | 08:06 AM
zanelefko's Avatar
thinking about it, idk how it would be installed backwards as the 02 sensor bungs would be in the wrong location?
Old Nov 23, 2013 | 09:35 AM
nikmoretto's Avatar
is it rattling on the heat shield?
Old Nov 23, 2013 | 10:51 AM
aznnightkidz's Avatar
I recently had this problem also after a ETS test pipe install. I bought my car to a mechanic and found out the bolts were rusted and i thought i tightened all bolts when i put it on, but it was because of 2 bolts that was making the whole downpipe and testpipe vibrate and rattle. Just check all bolts might need to be replaced or just tightened
Old Nov 25, 2013 | 06:25 AM
zanelefko's Avatar
test pipe is on the correct way, there is a hanger to line it up. None of the bolts, wideband sensor, or 02 sensors are loose. It is very weird, I will hit the pipe with my hand (to make it vibrate) and the will make a metallic rattle noise, I confirmed it doesnt touch ANYTHING! There is a bout a 1.5 inch gap around it so I know it is not vibrating and hitting any heat shields. it is also very far from the driveshaft carrier bolts.
Looks like im just going to bite the bullet for a new test pipe.
/thread
J!n K@z@mA
May 10, 2017 05:23 PM
jbuhrman
28
May 2, 2016 12:08 PM
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
stackhouse
Jul 7, 2011 06:41 PM
WADADLIG_OZ
14
Feb 20, 2004 03:57 AM
