FP Black or GTX3076R
Old Jul 3, 2014 | 11:45 PM
evokun's Avatar
Hellow.
I need 550WHP and low RPM spool.
Which FP Black and ATP GTX3076R is good?
My car 2.2L engine
Thank you
Old Jul 4, 2014 | 11:06 AM
alsong2002's Avatar
the black is discontinued.
gtx3076 sucks.
you should get gtx3576 or 3582.
either turbo you wont get low rpm spool. they are big turbo for top end power
Old Jul 4, 2014 | 11:25 AM
evokun's Avatar
Thank you.
FP Black is discontinued??
OH MY GOD....
Old Jul 15, 2014 | 11:35 PM
Centralcalievo's Avatar
I have an ATP gtx3582 for sale. Only 1,000 miles. Text me (559) 239-5204
Old Jul 16, 2014 | 11:53 AM
Hiboost's Avatar
The GTX30 was fine when I ran it but you can only expect around 500 whp out of that turbo. For a turbo capable of 550 whp you will want a EF4, GTX3576r, EFR7670, or AMS 750R kit to get the job done. 20 psi spool in 4th gear will probably kick in around 3600 rpm at best but you will get the power that way.
Old Jul 17, 2014 | 07:32 AM
IRPerformance's Avatar
3076 doesn't have enough turbine for the size of the compressor hence why the poor results on these cars. Either you want a 3071 and be in the low 400 whp range, or move up to the 3576 or 3582 and make 500+ and have slightly more lag.
Old Jul 17, 2014 | 10:50 AM
lbcevo's Avatar
Originally Posted by evokun
Thank you.
OH MY GOD....
I spoke to FP last week and production of the FP Black is temporarily on hold, it is not discontinued. They have a parts shortage.
This was directly from them, I think it was Robert. So until we hear otherwise, the FP Black is not discontinued and will be available again in the future when parts supply issues are resolved.
Old Jul 18, 2014 | 09:24 AM
alsong2002's Avatar
did they give you time frame?
Old Jul 18, 2014 | 09:25 AM
alsong2002's Avatar
Originally Posted by IRPerformance
3076 doesn't have enough compressor for the turbine size, hence why the poor results on these cars. Either you want a 3071 and be in the low 400 whp range, or move up to the 3576 or 3582 and make 500+ and have slightly more lag.
that on pump or e85?
Old Jul 22, 2014 | 09:09 PM
lbcevo's Avatar
No, I didn't get a time frame.
Old Jul 23, 2014 | 07:41 PM
klattr1's Avatar
It's more the other way around. It doesn't have a big enough turbine wheel to match the already large compressor wheel. The 3576 and the 3076 share the same compressor wheel.
Old Jul 23, 2014 | 09:02 PM
You're right. Was a rough night last night
GT3071R
Horsepower (estimated) 475
Compressor Wheel Inducer 53.1mm
Compressor Wheel Exducer 71.0mm
Compressor Wheel Trim 56
Compressor Housing A/R 0.60
Turbine Wheel Diameter 60.0mm
Turbine Housing A/R 0.73
GT3076R
Horsepower (estimated) 525
Compressor Wheel Inducer 57.0mm
Compressor Wheel Exducer 76.2mm
Turbine Housing A/R 0.94
Old Aug 3, 2014 | 05:41 AM
nalani69's Avatar
i think the gtx series is rated somewhat higher. if im not mistaken you can make 500 on the gtx3071. just need a 3,5 inch maf e85 a big enough fuel pump and injectors
KOOLER
14
Nov 7, 2017 08:03 AM
SpeedI2acerX
13
Nov 4, 2016 01:40 PM
riceball777
21
Dec 12, 2015 07:18 AM
MRadjahoe
40
Jan 20, 2012 09:27 AM
01CBR929
152
Aug 22, 2011 09:48 AM
